AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > Audio Area > Audio theory, Setup and Chat
Forum Jump
Old 12-31-06, 02:31 PM   #1   |  Link
Votan
New Member
Connecting Receiver to Computer
I want to connect the record-out on my receiver to the line-in on my computer so that I can transfer some LP's to CD. It will require a cable run of 14 or 15 feet to connect the two units. I'm wondering if I need to be concerned about high frequency loss in a cable of that length. Should I use standard RCA type cables or something a bit more expensive? Thanks for any suggestions.
Votan is offline   Reply With Quote
Old 12-31-06, 02:50 PM   #2   |  Link
ashutoshsm
Head-Spinning Good!
For analog stereo, RCA ables will be fine.
__________________
*ashu*
ashutoshsm is offline   Reply With Quote
Old 12-31-06, 02:56 PM   #3   |  Link
mattdp
HighlyAdvancedMember
I second that notion.
BTW,
If you are looking for some good audio capture software, I recommend Audacity. It's simple to use, totally free and has pop/click removal and dc offset removal built right in.
__________________
http://rochestermnhd.blogspot.com/ - Tech 55901. Tech news for Rochester. Authored by mattdp and gjvrieze.
TV Fool
FM Fool
A/V Hacks (my Blog)
mattdp is offline   Reply With Quote
Old 12-31-06, 03:10 PM   #4   |  Link
Votan
New Member
Thanks guys for responding to my post. I'm glad that I decided to post here. I had originally planned to buy a separate pre-amp to use right at the computer since I thought the cable would be too long. A friend suggested that 15 feet would be OK but I just wanted to make sure. Thanks for the info on Audacity. I'll download it today.
Old 12-31-06, 03:20 PM   #5   |  Link
ChrisWiggles
Perpetually Confused
That length should be just fine. That's not even a particularly long length for video which is WAY more demanding than audio. The frequencies for an analog signal are gigantic compared to video signals, and with high-quality cable I wouldn't even be particularly concerned about signal rolloff with video signals which are many thousands of times higher in frequency.
If you want the best though: bluejeanscable.com
And very reasonable pricing. Piece of mind if you want it.
__________________
Source Settings Guide
Discover the best radio station on earth: kexp.org
ChrisWiggles is offline   Reply With Quote
Old 12-31-06, 08:21 PM   #6   |  Link
indil377
This doesn't make any sense.
__________________
Matt D. Sherer CET, CTS-I,ISF-C
indil377 is offline   Reply With Quote
Old 12-31-06, 09:30 PM   #7   |  Link
ChrisWiggles
What doesn't make sense?
__________________
Old 12-31-06, 11:19 PM   #8   |  Link
indil377
This:
__________________
Old 01-01-07, 04:44 AM   #9   |  Link
ChrisWiggles
I understand that. How does that not make sense?
video frequencies are much higher than analog audio and are much more sensitive to cabling issues. And at these lengths I wouldn't be particularly concerned about rolloff with the frequencies invovled with vide, let alone with analog audio which are far lower in freq (much larger in size of wavelength).,
__________________
Old 01-01-07, 08:49 AM   #10   |  Link
indil377
First you wrote this:
"The frequencies for an analog signal are gigantic compared to video signals,
I am assuming that the analog signal you are referring to is audio and you say that analog audio frequencies are gigantic compared to video?
Then you wrote this:
Which is the opposite of what you wrote before. Now you say that video is higher in frequency.
__________________
Old 01-01-07, 11:53 AM   #11   |  Link
mattdp
True, video is much higher frequency than audio, and 15ft really is nothing to be concerned about in either realm.
__________________
TV Fool
FM Fool
A/V Hacks (my Blog)
Old 01-01-07, 03:11 PM   #12   |  Link
ChrisWiggles
Sorry, you're right that is confusing. When I said gigantic I was referring to wavelength size. Frequencies don't have a "size" dimension. Analog audio is much lower in frequency (audio frequencies) and much larger in wavelength. Hope that clarifies? The bottom line is that analog audio is far less critical a signal and is more resiliant to cabling issues than video which is much more difficult to transmit and handle properly without degradation.
__________________
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.16464496 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
