#1 | Link |
Will SD CRT be harmed by viewing digital 16:9 fmts?
Sorry if thread topic was a bit confusing, but tried to put as much info as possible..
The question relates to: If I get a SD 4:3 set and watch programs that are on digital channels, it would seem (to this newbie) that many are (and more in future will be) in 16:9 format and thus cause black bars on top/bottom in order to be able to see entire pix...in the Toshiba manual I've read online, it specifically warns about doing this too often...and Samsung says limit this to 15% of total usage per week! But Sony doesn't say this in their manual, so are they better quality and not subject to problems? They do warn about games and logos and such..but not the bars, as far as I can see... I can see burn-in occuring with logos and such, but I don't quite get how black bars would cause this... Thanks! |
#9 | Link |
http://en.wikipedia.org/wiki/Phosphor_burn-in
ALL phospher based displays can be affected by uneven phospher wear. Period. It doesn't matter who the manufacturer is. The statement that a particular brand of CRT televisions do not suffer from burn in is completly incorrect. |
#10 | Link | |
The examples that I've seen of CRT burn-in are extreme, and frankly, I don't worry about it at all. Of course, any new 4:3 CRT TV should have a zoom feature so you can just watch in full screen and not worry about this. I have a Sony 4:3 SDTV, and I prefer to watch widescreen programming as-is, so that is what I do. I'll eat my hat if it ever develops a noticeable burn-in problem.
It's pretty much unrelated to this topic, but just FYI, 4:3 CRTs don't all display 16:9 programming the same way. Some TVs compress the image vertically so that all of the scan lines are used for the 16:9 content you are viewing. I recommend that you buy a TV with that feature. There is a very noticeable difference in PQ. |
#11 | Link | |
AVS CLUB MEMBER
The only reason I responded here is because I am interested in the potential effect on my SONY 36KDxs HD set. This set smart sizes a 1080i or 720p signal into a 16x9 window. Unfortunatedly he tv's zoom controls result in overscan of a 4:3 window so that's not a particularly attractive option. I have been resorting to watching S-video feed for 4:3 material on HD shows - but whether or not burn in happens is certainly another factor. I suppose in the long run won't matter that much because the region of most interest will be the 16:9 window and I assume that will not be affected by the burn in? |
#12 | Link | ||
#13 | Link |
I've been using SD CRTs for about 20 years now (video games, widescreen movies, camcorders, you name it), and the only burn in I've ever seen was on a 21" CRT TV. Because I used to leave the on-screen clock on whenever the TV was on. And I'm talking about a period of years. I was warned not to do it, but live and learn.
By the way, that 15 year old 21" TV is now out in the garage- still works fine, and looks fine. There's just this faint little blur down in the left hand corner where the clock used to glow. In other words, don't worry about it, and don't leave the onscreen clock on ![]() |
#14 | Link |
On a 4:3 TV (20 years old) watching 4:3 material... no one will see "burn-in", since all of the phosphors are aging "gracefully" over the entire display area.
With "black bars" being presented, the phophors will not age. Therefore, over time, you can/will see symptoms. Without following proper setup/precautions, you will see the effect over time. I'm not saying you have to be obsessive, but just be aware. |
#15 | Link | |
If you keep the contrast at halfway or below you should not notice burn in for many years no matter what you watch. Video hints: http://members.aol.com/ajaynejr/video.htm |
| Bookmarks |
| Thread Tools | |
