#3 | Link |
In agreement
I would have to agree though not having that receiver the msg sounds like both
of your front speakers are "out of phase". You need to reverse the speaker wires at either the speaker or the amp, but not both. And make sure the amp is OFF, even unplugged when you do this work. Next time get some speaker wire that's marked so you can tell which wire is + and which is -. It's a lot easier than trial & error:-) br ![]()
__________________
Bll |
#4 | Link | |
#5 | Link | |
#6 | Link |
Again im having this problem 6 months later, I just moved into my new house and its just bugging me, i did auto cal and its saying the same thing , every speaker is out of phase yet everything IS hooked up correctly, Now do i stick with everything being technically hooked up 100% by standard(red to red -black to black) or do i swap them so the receiver thinks they are in phase.
I did this a few months back and i really didnt notice any sound difference at all but the auto cal went all the way through and finished and actually asked me to save my settings. Any advice would be greatly appreciated! |
#7 | Link |
AV Consultant
AVS GOLD CLUB MEMBER
I have found some speakers are wired wrong internally, but receiver phase testing is not 100% correct either. The simplest test would be to play the Avia speaker phase test and see if you can determine which wiring scenario is best. Another option would be to purchase equipment to measure phase or hire someone who can. The last option is to just forget it. Most of the auto calibration tools are a mess.
#8 | Link | |
2. If it says that only some are out of phase, then check your wiring carefully. If wired correctly, ignore the warning as some such auto-setups can be misled by room modes or shifted phase wiring inside the speakers. 3. In general, trust your careful inspection of the wiring.
__________________
Kal Rubinson "Music in the Round" Contributing Editor, Stereophile www.stereophile.com/musicintheround/ |
#11 | Link | |
__________________
#13 | Link | |
Use a tape measure for distance, and use test tones for the phase check. It may take a bit longer, but he still gets a fully calibrated system... Mark
__________________
Mark Techer |
#14 | Link | |
where do you measure to?, the tv or the listening posistion |
#15 | Link | |
Second, the same tools would be required for getting the acoustic delay for the subwoofer since it must encompass both physical distance and the delay introduced by the various filters through which the signal passes. MY experience with most auto setups (only one of the ones I have used failed and that quite obviously) is that they concur with physical and DSP-based independent measurements.
__________________
#16 | Link | |||
Mark
__________________
Mark Techer |
#18 | Link | ||||
__________________
#19 | Link | |
AV Consultant
I had one case where the distances were so wrong I was stunned. I asked the consumer where he placed the microphone he said he placed it in front of the receiver. I asked him why he thought that was correct. His reply was that he thought the receiver needed to know where it was in the room relative to the speakers. I have also seen many automatic systems with speakers wired to the wrong ones because most never have a voice say left, center, right.... Add to this connection errors and wrong switch settings and I find almost no sound systems are even close and it does not seem to matter whether a store did it or the consumer. In my opinion these automatic systems will not work for most people until they improve the on screen tutorials and provide feedback when a measurement is wrong or suspect. They should also provide tests for as much of the system as possible instead of just the receiver or preamp/amplifier. Many of the problems originate in the source or between the source and the receiver and must to found at that point. |
#20 | Link | |
Guest
#21 | Link | |
AV Consultant
Second, many sources require changes in the settings to obtain the best sound quality. Some sources require turning on bitstream (DD/DTS...) otherwise they will output PCM and toss the LFE channel. Some of the new HD players will perform bass management over LPCM and mess things up if settings are not correct in the player. This will potentially toss information. Other players may not handshake properly with receivers over HDMI and require manual intervention to obtain the best signal. The PS3 for example supports this type of setup. Some receivers do not process the LFE channel correctly over LPCM. The key thing is to use quality test material for the various sound formats to find all of these issues. I currently use DTS, DD, PCM, TrueHD and DD+ and measure and listen to a wide range of test signals and recordings. These will help find these issues along with other problems that can be corrected. |
#23 | Link |
Super Duper Member
I'm still wondering whether that error message, "FR/FL Caution Phase", means the right and left speaker are out of phase with one another, or that they're both out of phase with the rest of the speakers.
__________________
"All men are frauds. The only difference between them is that some admit it. I myself deny it." |
#24 | Link | ||||
__________________
#25 | Link | |
__________________
#26 | Link | |
They should put a peel-off decal over the face and rear panel of all AVRs with the same message...
__________________
Don't look too hard for black and white in a grayscale world. |
#27 | Link |
AV Consultant
Here are some client comments from people who have made some attempt at this and then had me work on their system.
http://www.avsforum.com/avs-vb/showt...&&#post7690864 (Denon) http://www.avsforum.com/avs-vb/showt...04#post6845804 (Pioneer) http://www.avsforum.com/avs-vb/showt...&#post10579368 (Yamaha) http://www.avsforum.com/avs-vb/showt...93#post8799293 (Panasonic) http://www.avsforum.com/avs-vb/showt...&&#post8376824 (Meridian) |
#28 | Link | |
Albert Thomas Damico
#29 | Link | |
I do not use auto Eq, but I use large mains along with smaller center and surround speakers (same brand & family). My main R & L 3 way speakers are in fact wired in reverse polarity for two out of the three drivers (mid and tweeter) due to the order of the crossover. I wire the center and surrounds in reverse polarity (red to black) to get all of the speakers to be in phase with each other. As an alternate, I could have wired the R & L mains plus the subwoofer in reverse polarity. I am wondering what people use for speakers when they fail this test! |
#30 | Link | |
AV Consultant
Out of all of my clients I have only seen two good audio installations done by others and neither used any automated setup routine. One was by a professional using quality equipment in LA and the other was by a skilled amateur with a great ear in Boston. This is based on many hundreds of clients most of whom are more into this stuff than my average friend or relative. |
| Bookmarks |
| Thread Tools | |
