AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > A/V Control & Automation > Remote Control Area
Forum Jump
Old 12-31-06, 08:23 PM   #1   |  Link
TD30
New Member
Harmony 360 issue with HR10-250 TiVo
Hi all, maybe somebody can help me out with a strange one here? I am getting intermittent response using my Harmony 360 remote with my HD TiVo box (HR10-250). If I press a key, sometimes the TiVo sees it and sometimes not. I can tell because a little yellow LED will light when the TiVo sees an IR command. Keep in mind, I have been through the "slow response" thread and none of that has helped.
I believe I can explain exactly what is going on although I cannot explain why. I realize this probably sounds crazy, but I have tested this over and over again. If I place my hand in front of the remote (blocking a DIRECT IR path), then the TiVo accepts all commands promptly. If I point the remote at the TiVo unit normally from my sofa (without blocking), it misses some of the commands sent. However, if I point the remote directly at the TiVo from a very close distance (about 3 feet or less) it works perfectly. My sofa is a normal distance from the TiVo (~10 ft).
Any ideas on what is happening here?
TD30 is offline   Reply With Quote
Old 12-31-06, 10:22 PM   #2   |  Link
tgibbs
Have you tried increasing the number of repeats?
tgibbs is offline   Reply With Quote
Old 01-01-07, 09:51 AM   #3   |  Link
TD30
New Member
Yes, tried increasing and decreasing the repeats with no real difference. If I set it too high (like 3), it will starting getting multiple commands when it receives the command at all. Thanks.
Old 01-02-07, 01:08 PM   #4   |  Link
TD30
New Member
No ideas huh?
Old 01-02-07, 11:07 PM   #5   |  Link
tokerblue
If you stand next to the Tivo and it works fine, it could be that your remote has a bad IR emitter. I have the HR10-250 and I sit back 10 feet and my 880 has no problems sending signals.
Here are the settings that I have found to be optimal on my Tivo.
Repeats: 1
Power On Delay: 300
Interkey Delay: 0
Interdevice Delay: 100
tokerblue is offline   Reply With Quote
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.11534905 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
