AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > Audio Area > Audio theory, Setup and Chat
Forum Jump
Old 01-01-07, 08:32 AM   #1   |  Link
Mike99
Question Optical Cable Quality ?
Is there any difference in optical cables? I realize fiber is fiber, but what about connectors and bending radius? Some have metal ferrules and supposedly better strain reliefs. Right now I am using a cheap one from Walmart & it works, but I need to get a few more. Monoprice.com lists a regular, a Premium and a Metallic Body version (which just looks like a metal ferrule). Not much of a price difference between each model which makes it tempting to upgrade. But the connectors are all plastic anyway where they plug into the components.
Any comments would be appreciated if the cheapest ones work & hold up just as well as the expensive ones.
Thanks in advance.
Mike99 is offline   Reply With Quote
Old 01-01-07, 01:56 PM   #2   |  Link
Davespy
I have used cheap radioshack optical (toslink) and also more expensive cables but have not noticed a significant difference. I have heard that digital coax is better if you have that option. I sure am sure if you spent a few hundred as opposed to 20 bucks there will be a difference but i personally have no interest in finding out on my budget.
Davespy is offline   Reply With Quote
Old 01-01-07, 07:20 PM   #3   |  Link
SayNoToPistons
I would go for a somewhat cheap glass optical cable and just use that instead. Won't make much of a difference if you buy much pricier ones. The glass optical cables on ebay works fine.
SayNoToPistons is offline   Reply With Quote
Old 01-01-07, 08:09 PM   #4   |  Link
louthewiz
Resident Enforcer
http://www.monoprice.com/products/su...d=10229&style=
louthewiz is offline   Reply With Quote
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.09833002 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
