AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > HDTV > HDTV Recorders
Forum Jump
Old 01-01-07, 10:58 AM   #1   |  Link
LukieDog
8300HD How to Disable Sleep Mode?
I'm trying to record output from the 8300HD by leaving on play and running a standalone DVD Recorder. This is at night,when I turn my tv off for the evening. The problem is that after 2 hours, the 8300HD enters sleep mode and then I get a black screen. Is there any way to prevent this? If I left the TV on, I am guessing I will accomplish what I want, is this correct? I'd rather not leave it on. It does have an HDMI connection to the TV.
LukieDog is offline   Reply With Quote
Old 01-01-07, 08:50 PM   #2   |  Link
DoubleDAZ
Cox - SARA 1.89.27.1
Does it always stop after 2 hours or does it depend on when you start it? Have you tried it during the day and it still stops after 2 hours? There is a auto-shutdown feature that cableco's use at a predetermined time each night, ours is at 1:15 am, and it can only be overridden by pressing a key when the prompt appears. I don't know if this is what you are experiencing or not.
__________________
Cheers, Dave
DoubleDAZ is offline   Reply With Quote
Old 03-14-07, 02:28 AM   #3   |  Link
mdeligny
I have Comcast and there is actually a sleep mode setting in my menu area to disable it or enable it. I have 1.88.25. I don't think my damn 1394's are active and I really wish they were.
mdeligny is offline   Reply With Quote
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.10301089 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
