#1 | Link |
Hi,
For you electronics people a theoretical question. You have an amp with only 2 speaker hookups, front left and front right. You have 4 speakers, all 8 ohm. Your amp says it will handle 4, 6, 8, & 16 ohm speakers. Can the 2 positive wires from 2 speakers be connected, same done with - wires, then both speakers be plugged into the left front, then the same done with the other 2 speakers and hooked up to right front? If this will work would you effectively have a 16 ohm speaker on each channel with each speaker getting half the rated output wattage? TIA Bill (you can email me at bllreed@hotmail.com or PM me, thanks.)
__________________
Bll |
#3 | Link |
Series vs parallel resistance is sometimes a bit easier to grasp with a picture.
This page has a nice pictorial explantation of series vs parallel wiring. http://colomar.com/Shavano/speaker.html ![]()
__________________
The fact that an opinion has been widely held is no evidence whatever that it is not utterly absurd. -Bertrand Russell |
| Bookmarks |
| Thread Tools | |
