AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > Audio Area > Audio theory, Setup and Chat
Forum Jump
Old 01-01-07, 01:16 PM   #1   |  Link
osiris13
Anyone not use a center channel?
I've heard of a few people who actually prefer systems without center channels, just wondering if anyone here is a proponent of the idea and maybe can explain why?
osiris13 is offline   Reply With Quote
Old 01-01-07, 06:48 PM   #2   |  Link
ChrisWiggles
Perpetually Confused
It depends on the content. Many many people listen to stereo in stereo despite having a surround sound system. Count me in that group. I'd wager that most critical listeners listen this way.
As for multichannel content that has multiple channels including a center channel, I think most listen with a center channel, but some don't. The problem with not using a center for multichannel content is that anyone else not in the sweetspot/on-axis won't have a good center image. But on-axis, the results can be quite good.
__________________
Source Settings Guide
Discover the best radio station on earth: kexp.org
ChrisWiggles is offline   Reply With Quote
Old 01-01-07, 07:13 PM   #3   |  Link
Davinleeds
AVS GOLD CLUB MEMBER
When I listen to music, no center. With the advent of surround for video/movies, I changed my av receiver. With Video music channels it helps to focus the music, but if it's solely music, I change it . Four channel was around before the center channel add on. Quadraphonic, remember?
Davinleeds is offline   Reply With Quote
Old 01-01-07, 07:22 PM   #4   |  Link
Kal Rubinson
It is not a big deal. You simply need as many speaker channels as there are discrete signal channels in the source; anything less (or more) is less than optimum for accurate reproduction. Thus, stereo (2 channel) in and stereo (2 channel) out is fine. However, if there is a real center signal (not a synthesized one), it cannot be accurately reproduced by splitting and mixing it into the L/R channels although many find it acceptable or cannot do otherwise for esthetic or WAF reasons.
Quad was an unfortunate effort that was not based on reliable psychoacoustic research.
__________________
Kal Rubinson
"Music in the Round"
Contributing Editor, Stereophile
www.stereophile.com/musicintheround/
Kal Rubinson is offline   Reply With Quote
Old 01-01-07, 07:37 PM   #5   |  Link
Davinleeds
But Quad was a step in the direction we have now.
Old 01-01-07, 07:47 PM   #6   |  Link
Kal Rubinson
Not as I see it. Technologically, both Quad8 nor SQ were dead ends. As for the mixing/mastering, most of it was egregiously flawed. Still, it showed us the possibilities.
__________________
Kal Rubinson
Old 01-01-07, 08:08 PM   #7   |  Link
Davinleeds
Well? Step in the direction? You're last sentence?
Old 01-01-07, 08:10 PM   #8   |  Link
Kal Rubinson
OK. Depends on how you look at it. At the time, I found it silly.
__________________
Kal Rubinson
Old 01-01-07, 08:25 PM   #9   |  Link
Davinleeds
I found it groundbreaking- the thought that you could have 4 speakers cranking - and in those days they cranked, verses standard stereo. And I appreciate you and your work, It's only I, as stated, prefer listening to non-center channel when not "centered" on the video. Wasn't the center channel born from the video? Must have been in theaters years before we realized what it was. Evolution is anything and part of everything that "just" occured .
Old 01-01-07, 08:32 PM   #10   |  Link
ChrisWiggles
It was really born from the need to have a center image for large venues where the vast majority of listeners are not on-axis, for instance at a movie theater where you want dialogue to be centered on the screen, and not coming from one side or the other depending on where you're sitting. And center channels (in content and in playback) are extremely effective at doing this. If everyone is sitting in a straight line right on-axis, the need for having a center channel (either in content or in playback) is reduced.
__________________
Old 01-01-07, 08:46 PM   #11   |  Link
Davinleeds
Early video=theater? "Must have been in theaters before we realized what it was." Kal, Looking up your subscription rates.
Old 01-01-07, 08:50 PM   #12   |  Link
Kal Rubinson
Actually, it predates quad and derives from the original "stereo" experiments at EMI and ATT where it was determined that a minimum of three front channels wererequired for stereo. That we ended up with only 2-channel stereo is a reflection of the technical difficulty in delivering more than 2 channels in a mass medium, at that time, the LP. Thus, it has nothing to do with video or with surround but with the reproduction of a good frontal image.
__________________
Kal Rubinson
Old 01-01-07, 09:01 PM   #13   |  Link
sdurani
No. The centre channel was created specifically for music playback.
A 3-speaker front soundstage dates back to the early 1930s when Bell Labs was experimenting with transitioning from mono to stereo. They found that a minimum of 3 channels/speakers was needed to recreate the wavefront of the original sonic event; anything less being a compromise.
Its first use in film came at the end of that same decade with Walt Disney's 'Fantasia', which had a 3-channel soundtrack. Since the film contained practically no dialogue (a couple of lines where conductor Leopold Stokowski greets Mickey Mouse), the centre channel was used primarily for music playback. No different than the way Bell Labs had been using it all along.
There were also some classical recordings done in 3-channel stereo, which had to be down-mixed to 2 channels for release on vinyl records. (Some of those recordings finally got released in their original 3-channel versions on SACD.)
Centre channel use for "video" (i.e., locking the dialogue to the screen) didn't occur till decades after the above events.
Sanjay
sdurani is offline   Reply With Quote
Old 01-01-07, 09:03 PM   #14   |  Link
Davinleeds
So tell me how it intergrates with what CW says about theater. Theater didn't push center channel use/the idea of? Center channel theology was later reborn? Theater equals pre video.
Old 01-01-07, 09:05 PM   #15   |  Link
Davinleeds
Remember, I refer to video as early theater. Kal refers to 3 channel.
Old 01-01-07, 09:22 PM   #16   |  Link
Davinleeds
Sanjay
"Wasn't the center channel born from the video?"
What changed? Deserted during the analog era? We have 3 channel for Fantasia, 2 channel for rock and roll, then MTV???
Old 01-01-07, 10:10 PM   #17   |  Link
Davinleeds
Appreciate the discussion.
Old 01-01-07, 10:23 PM   #18   |  Link
Kal Rubinson
OK. I might respond if I understood what you are asking.
__________________
Kal Rubinson
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.21420002 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
