#1 | Link |
What can I do with this room.
I'm hoping someone here has a good idea as to what can be done with this room. Its a good sized room, but its probably about one of the worst possible as far as audio is concerned. [it was like this when I moved in] The lack of any sort of carpet etc tends to make the low end seem very muddy I think. The narrow width of the area where the TV is also makes the sound stage waaay to narrow. Actualy, the narrow sound stage is the main thing I want to fix. I'm willing to move just about everything in the room, so if you have an idea, tell me.
BTW: the setup is... AVR 435 Athena Audition AS-F2s, AS-C1, AS-B1s now for the pictures... ![]() Last edited by Vulcanium; 01-01-07 at 02:01 PM.. Reason: fixing images. |
#2 | Link |
Perpetually Confused
I'd just start by attacking it with absorption. Fiberglass panels on many of those wall surfaces, some thick area rugs can help, etc. Doing this won't cost you whole lot and will make a profound difference. I can tell that the room is probably an echoey fatiguing mess as it stands now.
#3 | Link |
"The lack of any sort of carpet etc tends to make the low end seem very muddy I think."
Putting in carpet is not going to help at all with muddy bass. For that you would need to put bass traps in as many corners as you can in that room. I would start with the front corners and go from there. Also you would need to put some thinner panels on the first reflections and a few thicker panels on the back wall. Hope that helps get you started! Glenn
__________________
GIK Acoustics |
#4 | Link | |
Acoustics Specialist
--Ethan
__________________
RealTraps The acoustic treatment experts ---------------- Amazing electric guitar video |
| Bookmarks |
| Thread Tools | |
