AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > A/V Control & Automation > Remote Control Area
Forum Jump
Old 01-01-07, 02:40 PM   #1   |  Link
NormanB
Need Denon 1803 code for Comcast DVR remote.
I have spent hours searching for this code. It is a fairly common receiver, yet Comcast does not offer a code for it? I just want to be able to power it on & maybe adjust the volume for crying out loud! Any help would be appreciated otherwise I will spend the $20 for a Sony VL600. Not sure if I can program a "favorite channels" button though. Thanx in advance.
NormanB is offline   Reply With Quote
Old 01-01-07, 06:02 PM   #2   |  Link
Kupakai
Which remote do you have? Is it this one? If it is, did you already try AUX/1360? Did any of the buttons work?
Kupakai is offline   Reply With Quote
Old 01-01-07, 10:55 PM   #3   |  Link
NormanB
Yes, that's the remote. I just tried 1360...no luck.. No on/off or volume control atleast. Thanx for your efforts. Any other #'s I should try?
Old 01-01-07, 11:32 PM   #4   |  Link
Kupakai
As a test, see if you can do this.
1. Set the AUX to 1360 (make sure AUX button blinks twice after setting to confirm)
2. press AUX
3. press (not hold) SETUP
4. point remote to receiver and press 01977
Does it turn off or on?
You can try 01973 for volume up and 01909 for volume down. If it works, I'll show you how to assign those to buttons. If not, sorry, I'm out of tricks.
Old 01-02-07, 01:03 AM   #5   |  Link
NormanB
Interestingly enough, it controlled my inputs on the Denon. Every # was a different audio input. Seems like we are heading in the right direction.. Did you see that Fiesta Bowl? What a game!
Old 01-02-07, 09:48 AM   #6   |  Link
Kupakai
Missed the game, but wish I had watched it!
I didn't expect the result (the remote, not the game ), but if you want to try to continue with this, you can tell me what each code activated and I can try to figure out what's going on. By the way, if you are wondering (and so you know I not just giving you random numbers ), I'm getting the codes from "EFC5" column on this:
Code:
Function	OBC	DEV	EFC5
VirtSurround	137	2	01963
Display		222	2	01857
Return		130	2	01915
up arrow	163	12	34047
down arrow	164	12	33823
left arrow	127	12	33988
right arrow	221	2	01921
System setup	160	12	33855
select/menu	224	2	01853
Ext In		181	12	33943
vol up		241	2	01973
vol down	242	2	01909
mute		240	2	01845
channel up	214	12	33873
channel down	213	12	33937
power toggle	193	2	01977
power on	225	2	01981
power off	226	2	01917
1. Phono	195	2	02041
6. VCR1		205	2	01929
2. CD		196	2	01817
9. CDR/Tape1	210	2	01905
7. VCR2		206	2	01865
8. V. Aux	204	2	01801
3. Tuner	197	2	01945
5. TV/DBS	201	2	01961
4. DVD/VDP	227	2	02045
Memory		204	12	33801
Band		215	12	34001
Tuning Up	217	12	33953
Test Tone	234	2	01901
Direct		158	12	33859
Analog		220	2	01793
Stereo		157	12	33923
DTS		228	2	01821
Input Mode	182	12	33879
5/6Ch St	168	12	33839
surround mode	230	2	01885
Surround Param	161	12	33983
Tuning Down	218	12	33889
Tuner Mode	216	12	33825
Shift		205	12	33929
which is from an upgrade file at the JP1 remote control site, but it's for slightly different protocol which is not built in to your remote. Device 1360 should have been an equivalent protocol, but maybe not quite.
Old 01-02-07, 11:03 PM   #7   |  Link
NormanB
O.K. Kupakai- My remote is only recognizing 1 digit commands for the Denon
0=Analog
1=virt DVD
2=nothing
3=tuner
4=tv/DBS, in+D Opt1,6 channel stereo TV
5=in V aux, in=D opt, 6channel stereo aux
6= in phono, stereo phono
7= in VCR1, stereo VCR1
8= in CD, channel stereo cd
9= in CDR/tape, stereo tape
the comma represents my system scrolling to another function, Wierd.
Should I just step up for the Sony or Harmony?
Thanx again for all of your help, you have gone above & beyond...
Old 01-03-07, 12:00 AM   #8   |  Link
Edmund
to get the VOL commands:
1. aux
2. press and hold SETUP for two blinks
3. enter 9-9-3
4. press VOL DOWN
Edmund is offline   Reply With Quote
Old 01-03-07, 12:33 AM   #9   |  Link
Kupakai
1. aux
3. enter 9-9-3
4. press VOL DOWN
Aaah, didn't ask to check that
Norman, when you press the volume keys, does the "TV" button light come on? If it does, do the steps Edmund outlined. After that procedure, the "AUX" button light should come on when you press the volume keys (and the volume should work for the receiver).
Old 01-03-07, 01:19 PM   #10   |  Link
NormanB
At work right now, not going home tonight, but will try this out tomorrow night. You guys rock!
Old 01-07-07, 10:17 PM   #11   |  Link
NormanB
1/2 way there!
With the 993 advice, the remote is now able to control the volume on my Denon receiver! Thanx! If I could only turn the Denon off with this remote I would be a happy couch potato! Any more thoughts?
Old 01-07-07, 10:25 PM   #12   |  Link
Kupakai
Is the power button turning it on right now, and just not off, or is it just doing nothing?
Old 01-07-07, 10:42 PM   #13   |  Link
NormanB
Won't turn it on or off....
Old 01-07-07, 11:03 PM   #14   |  Link
Kupakai
From the chart I gave you before (above), Advanced code "01981" should be power on and "01917" should be power off for the device 1360. So, try this:
1. Press AUX
2. Press and hold SETUP (wait for two blinks)
3. Enter 9-9-4 (wait for two blinks)
4. Press SETUP (don't hold it)
5. Enter 0-1-9-8-1
6. Press "POWER" (will blink twice to confirm)
7. Press and hold SETUP (wait for two blinks)
8. Enter 9-9-4 (wait for two blinks)
9. Press SETUP (don't hold it)
10. Enter 0-1-9-1-7
11. Press SETUP (don't hold it)
12. Press "POWER" (will blink twice to confirm)
That should assign ON to "POWER" button and OFF to SHIFT-"POWER" (shift is press SETUP let go and then the button). If you'd rather set them to other keys, you can just replace the keys in the above instruction (step 6 and steps 11 and 12). Don't do step 11 if you don't want shifted keys. Also, you can reassign most keys, but not all. Some are reserved to always activate other devices (for example the arrow keys). Another suggestion for the set of ON/OFF keys you might want to use instead is "PIP CH+" and "PIP CH-" at the bottom.
Old 01-07-07, 11:32 PM   #15   |  Link
NormanB
It Works!
You are my hero! Denon goes on just by hitting "power" & off when I hit "setup" then "power". Simple enough! Thank you so much for your time & patience. I hope others with Denons & Comcast DVR will benefit as well. Happy New Year! -Norm
Old 07-18-07, 03:20 PM   #16   |  Link
sharmaswapnil
New Member
DHT 487 DV with Comcast
Hi,
I recently bought a Denon Home Theater - DHT 487DV and trying to configure Comcast HD Digital Cable box (Motorola model) using the Denon remote control. The code I have tried is - 476 (mentioned at hi fi remote link was 0476 but Denon remote accepts 3 digits so I dropped the leading zero)
Alternatively, I also tried to configure the Universal remote provided by Comcast to control my AV receiver but in vain too. The codes that I have tried are - 1104 and 1360
Please suggest a solution to control my components by either methods.
Thanks in advance!
Swapnil
sharmaswapnil is offline   Reply With Quote
Old 07-18-07, 03:50 PM   #17   |  Link
NormanB
I have no more information than above. The Comcast will turn my Denon on & off, that's about it. You may need to check out the $100 + universal remotes. Good luck!
Old 07-18-07, 05:03 PM   #18   |  Link
greeno
Or you can check out using a one-for-all remote ($20 or so). These JP1-able remotes can be made to control anything.
greeno is offline   Reply With Quote
Old 07-18-07, 05:21 PM   #19   |  Link
Kupakai
For the Denon remote, try codes for Jerrold or General Instrument from the Denon manual. Different remote manufactures will have different codes for devices so 0476 only applies to remotes from UEI (like One for All and some cable remotes).
Did the receiver respond to any keys with setup code AUX/1360? Denon tends to be fairly consistant with their ir codes. Did you try some of the steps above?
Actually, the Comcast remote (URC-1067) is also a JP1-able (JP1.x) remote as well and has enough memory to add decent amount of programming.
Old 07-18-07, 10:26 PM   #20   |  Link
sharmaswapnil
New Member
None of the codes worked !!
I am following the steps as mentioned in an earlier reply -
1 Find the 4-digit code number for your device.
2 Manually turn on the device you are setting the code for (used to verify you have the proper code).
3 Press and release the device key you want to program.
4 Press and hold the "Setup" key until device key blinks twice.
5 Type in the 4-digit code using the number keys.
6 If successful, you will get 2 blinks. If not successful, you get one long blink.
I am ending up with a long blink and none of the functions work.
Old 07-19-07, 03:01 PM   #21   |  Link
sharmaswapnil
New Member
I called up Denon Customer Support to check the codes for Comcast Box. Looks like they do not have any codes available.
[All that they support is listed at the back of the manual, Comcast is missing !]
Old 07-19-07, 03:16 PM   #22   |  Link
Kex
Wine & Travel
JP-1 or Harmony solution?
Is the Comcast remote not JP-1 capable? If so, you should be able to solve your issues that way for a small investment.
Otherwise, get a Harmony and kill two birds with one remote! Harmony remotes use a database of 175,000+ devices from 5,000+ brands, not codes and, for most people, are very easy to use. This would replace ALL of your old remotes with just one.
Kex is offline   Reply With Quote
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.24054694 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
