AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > Video Components > Cable, Digital Cable - Non-HDTV
Forum Jump
Old 01-01-07, 03:53 PM   #1   |  Link
eggman1964
New Member
Smile component to s-video
Hi all. I was wondering if anybody out there could confirm if this adapter setup will work. I want to convert component output from my projector into and older satellite receiver which only has composite and s-video inputs (4-pin). I have a component to 7-pin s-video adapter (from my Nvidia graphics card package) and then I would use a 7-pin to 4 pin s-video adapter to connect to my satellite receiver.
so this equates to the following:
component to 7 pin s-video to 4-pin-s-video.
thanks for any help!
Cheers,
Eggman1964
eggman1964 is offline   Reply With Quote
Old 01-01-07, 04:24 PM   #2   |  Link
miniz
OFFICAL HOME OF HDTV
Get a new satellite receiver. If your proj is HD, then please feed it an HD signal!
__________________
"PLEASE HELP STOP HDTV ABUSE! FEED YOUR HDTV AN HD SIGNAL!"
miniz is offline   Reply With Quote
Old 01-03-07, 09:18 AM   #3   |  Link
eggman1964
New Member
Thanks for your advice (or lack thereof) and I plan to do so eventually, but as I have an SD satellite for now I want to make use of it until I upgrade to an HD receiver for my satellite. So the question remains and I would appreciate any help on this.
Cheers,
Eggman1964
Old 01-03-07, 11:01 AM   #4   |  Link
Targus
Your projector has an input. The receiver has an output.
You cannot convert component to composite or s-video with 'a bunch of adaptors', you'd need an encoder.
Targus is offline   Reply With Quote
Old 01-03-07, 06:11 PM   #5   |  Link
miniz
AKA, it would be cheaper and A LOT easier to get an HD sat receiver. Why buy an HDTV then refuse to feed it an HD signal? Makes zero sense whatsoever. That's like buying a sportscar then refusing to drive it over 5 miles per hour.
__________________
Old 01-03-07, 07:06 PM   #6   |  Link
Ratman
Why do you care? Let the guy try to do what HE wants.
HD Fanaticism is no better than those that go door to door preaching the religious beliefs.
Ratman is offline   Reply With Quote
Old 01-03-07, 07:35 PM   #7   |  Link
miniz
because there is simply NO point to having something and not using it for what it is made for! I have no idea why someone would spend time converting component to S-Video when they could simply buy/lease/get for free a new box with the right connections?
__________________
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.11902595 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
