AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > A/V Control & Automation > Remote Control Area
Forum Jump
Old 01-01-07, 05:14 PM   #1   |  Link
FR0ST
remote control extender advice
I would like to move all my eqquipment to the computer room (next room), and control everything from my HT room, which IR extender do I need.
Soon to have plasms tv
Chris
Equpment list
PS Audio Quintet Power Center
Rotel RSP-1068
Rotel RMB-1075
Cambridge Audio Azur 540D
Cambridge Audio Azur 640C v.2
Paradigm Studio 60 v.3
Paradigm Studio CC570
Paradigm Studio ADP470
Panasonic CT34WX15
HSU VTF-3 MKII
FR0ST is offline   Reply With Quote
Old 01-01-07, 05:22 PM   #2   |  Link
FR0ST
Would those be suficient
http://www.audioholics.com/productre...olExtender.php
http://www.amazon.com/ATH-433-REMOTE...&s=electronics
Chris
Old 01-02-07, 09:31 AM   #3   |  Link
SteveOh_UK
New Member
Smile
I'm in need of advice on the very same thing Frost...
Lests hope someone with a little know how helps us out....
SteveOh_UK is offline   Reply With Quote
Old 01-02-07, 11:45 AM   #4   |  Link
ar7499
I recently purchased this repeater
http://www.mytvstore.com/product_id_010.html
it is much less money than many of the alternatives. It can work as a "blaster" to repeat the commands to every device at once, or you can buy
http://www.mytvstore.com/product_id_028.html , which is a four device wired emitter. I bought this and it all came to less than $50 with shipping.
So far I am VERY impressed with how well it works. There is no delay. The target sits right next to my lcd powered front projection screen, and I do not get any IR interference or bad signals as I feared I might. I only need the signal to be sent about 20', so range was not really a concern.
good luck,
ar
ar7499 is offline   Reply With Quote
Old 01-22-07, 02:10 PM   #5   |  Link
xiaoyu
Hi Chris,
I have two questions for ATH-433
1. Why do mannufacturer make two different frequency of this device (433 Mhz and 418 Mhz)?
2. Does this device work for Motorola cable HD-DVR remote?
xiaoyu is offline   Reply With Quote
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.12372088 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
