AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > A/V Control & Automation > Remote Control Area
Forum Jump
Old 01-01-07, 09:36 PM   #1   |  Link
PJ Saine
New Member
Smile Cabinet glass options?
New to site. And new big screen LCD HD TV.
Plan on hiding components (DVD, satellite box) in built-in cabinet below bookcase - taking out center panel and replacing it with a piece of glass. Clear glass would not be my favorite option: what are my other options? Seems like dark glass is on many component cabinets. Are there other options?
__________________
PJ Saine
Visit me on the web at:
http://www.pjsaine.com
PJ Saine is offline   Reply With Quote
Old 01-03-07, 08:07 PM   #2   |  Link
tonyn41
Glass can be tinted any color you like.
I would call a glass place and ask them.
You do realize that the tints could block out IR, so you should also consider RF remotes with IR blasters that can be mounted inside cabinet.
Another option is tinted acrylic, which I have seen in all colors of tints at ACE hardware stores. They will even cut it to your specs.
__________________
- Tony
tonyn41 is offline   Reply With Quote
Old 01-03-07, 08:53 PM   #3   |  Link
Ripper
I used tempered glass custom ordered at my local glass shop. I chose tempered due to my small child and that I have two 50" racks starting at the floor. Didn't want glass shards everywhere should an accident occur. The glass provided a cleaner look, and something more resistant to scratches and fingerprints. I ordered mine with a dark grey tint and it works great - no problems with a Pronto 6000 at 9 feet.
You could ask them for a sample piece of glass and take it home - aim your remote thru it and see if it works.
Mine cost me $90 each, complete with hole cut in it for a cam lock.
Ripper is offline   Reply With Quote
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.09348202 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
