AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > Home Entertainment & Theater Builder > Theater Room Items & Accessories
Forum Jump
Old 01-02-07, 09:12 AM   #1   |  Link
Daak
New Member
Power Strip with Auto-Cutoff
I live in an area where the power flickers on and off rapidly. This can go on for 10 seconds and I don't like it effecting any equipment much less audio/video/computer equipment. I know about uninteruptable power supplys but that seems like an expensive solution that just isn't needed. I wanted to know if there were any power strips/surge protectors that also have a feature that cuts power to the strip as soon as the voltage drops below a certain point. That way as soon as the power starts to flicker everything would just shut off rather than rapidly cycle on and off. Then I could just manually reset the strip when the power isn't acting up. Any ideas?
Daak is offline   Reply With Quote
Old 01-02-07, 11:14 AM   #2   |  Link
bakpakva
bakpakva's Avatar
AVS CLUB MEMBER
Classified Rating: 100% (1)
You might want to check out the Belkin PureAV power products. They will disconnect the power when it reaches set points. Occasionally you can find them on clearance. I picked up the PF60 some time ago, and that is what I use it for. I think the PF30 is much cheaper and may do what you are looking for.
bakpakva is offline   Reply With Quote
Old 01-03-07, 02:48 PM   #3   |  Link
zductive
The little 1s power blips have a side effect that we don't consider. My sp4805 will wake up and start projecting when a power glitch occurs. That means that the projector might be running for a few days until I return to the house. Either the short glitches need to be controlled by a UPS or, they need to be controlled by a shut down circuit.
zductive is offline   Reply With Quote
Old 01-04-07, 02:49 PM   #4   |  Link
Daak
New Member
I checked out the Belkin equipment. I'm looking for something less than $20. I figure a $7 surge protector has circuitry to cut off power when there is a surge so how much more expensive could it be to design something that cuts off power to the strip when it goes below a certain level? Hmm...
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.11000395 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
