#1 | Link |
New Member
Ok...i'll say it first.....i'm dense
Looking for optimal hook-up for my new Onkyo SR674 Receiver (has 2 hdmi inputs and 1 output) What I have to hook up: Maxent 50" Plasma HDTV Motorola DCT3412 I Cable Box w/HDMI connection (Comcast Provider) JVC TH-6 DVD Sony SA-WM500 Sub-Woofer JVC Speakers (no help needed- self explanatory on hooking these up) Do I run HDMI cable directly from cable box to tv or go thru the 674? Audio hook ups? etc, etc etc basically, i guess i need full wiring config for the best config. of everything if someone would be kind enough to help. thank you and happy new year |
#2 | Link |
Most will say "Why pass through more then ya have to" So IMO and im sure most others go direct HDMI from Cable box to TV. Then use Optical/coaxial audio cable from cable box direct to receiver. Do the same with the DVD player to TV Via best connection DVD player has HDMI? Component? Svideo? Composite
? same for audio then also. Good luck. |
| Bookmarks |
| Thread Tools | |
