AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > Audio Area > Audio theory, Setup and Chat
Forum Jump
Old 01-03-07, 09:57 AM   #1   |  Link
aktick
Cable to connect laptop to receiver?
Is there a cable that would let me connect the audio output on my laptop to my receiver (I'm assuming in via red/white stereo cables)?
Thanks a lot.
aktick is offline   Reply With Quote
Old 01-03-07, 10:29 AM   #2   |  Link
11001011
Señor Member
You need something like this.
255-045 6-Ft. 2-RCA Plugs to 3.5 Stereo Plug $7.00
You can probably get one for less at Radio Shack, Kmart, or even your local Dollar Store.
__________________
A 'phile and his money are soon parted...
11001011 is offline   Reply With Quote
Old 01-03-07, 11:12 AM   #3   |  Link
whoaru99
Thanks a lot.
Some laptops have digital output capability. If that is an option for the laptop and receiver, it may be a better choice.
You'd probably have to check the laptop documentation or with the mfg. to find out if that is an option. Unless, of course, you see a digital output jack on the case.
__________________
Don't look too hard for black and white in a grayscale world.
whoaru99 is offline   Reply With Quote
Old 01-03-07, 01:21 PM   #4   |  Link
aktick
I think it's just the ordinary Dell sound card, so I'm guessing no?
Old 01-03-07, 04:22 PM   #5   |  Link
whoaru99
It's hard to say. Even amongst the same models of laptop there seems to be the possibility of a myriad of different options.
In any case, the cable in one of the previous posts should get you going with an analog signal.
__________________
Old 01-03-07, 11:09 PM   #6   |  Link
bllreed
USB sound
I just bought a Pioneer VXS84TSXi receiver which has a USB input. A standard USB
A to B cable can be connected to a PC or laptop for streaming audio from the
computer through the receiver. You don't say what receiver you have but depending on the inputs you might be able to do something like I'm doing. I haven't actually tried this though I have it hooked up. As I have 5 or 6 other
sources for music and have only had the receiver for a few days it just hasn't
been a priority but when I get around to testing it I'll let you know how it sounds.
BR
__________________
Bll
bllreed is offline   Reply With Quote
Old 01-04-07, 09:47 AM   #7   |  Link
aktick
I have the Panny XR55...don't think it has USB, I'll check when I get home. Otherwise I'll just hit the RatShack on the way home.
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.12742305 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
