AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > Display Devices > Direct View (single tube) CRT Displays
Forum Jump
Old 01-03-07, 06:42 PM   #1   |  Link
homerrulez
19"-24" CRT monitors for PC
Now I did some research for the past few days and found that running a CRT HDTV on a PC isnta smart idea and the picture quality will not match that of a CRT monitor made for a pc. Why I dont know since they are CRTS. I will be looking to buy a CRT monitor around 19"-24". Now what I do know is very little but I was hoping to get soem help. I continued to do more research but still cant find anything on best CRT out there,
What would be the best 19"-24" CRTs that are out there for gaming and word processing. I looked up that term here on the search feature but I got a lot of posts that had nothing to do with what I was loking for.
homerrulez is offline   Reply With Quote
Old 01-03-07, 07:05 PM   #2   |  Link
MechanicalMan
The OOP Sony GDM-FW900 seems like a popular choice. I'm not sure what the best way to obtain one would be.
MechanicalMan is offline   Reply With Quote
Old 01-03-07, 07:20 PM   #3   |  Link
homerrulez
yea couldnt find it on ebay or CL
wow when you want to buy a ****** monitor, you got iy, when you wanna buy something wrth buying, it no where to be found. WoW
Old 01-03-07, 07:41 PM   #4   |  Link
homerrulez
would n e 1 reccomend this monitor this monitor ViewSonic-P220F
Old 01-04-07, 12:01 AM   #5   |  Link
MotorCityJoe
Dude, go to ebay. Type in 24' Sony monitor into the search bar. I'm using the Sony GDM-FW900 monitor and its awesome.
MotorCityJoe is offline   Reply With Quote
Old 01-04-07, 11:57 AM   #6   |  Link
homerrulez
found it but its a bit out of my range so I was looking at the viewsonic one p220f and might gett hat if its a good crt
Old 01-04-07, 04:49 PM   #7   |  Link
ag studios
Location: United Kingdom ( I dont see any Kingdom though.... )
NEC / MITSUBISHI, are the ultimate CRT monitors..............they are used by LUCAS FILMS.................nothing more to say !
Sony are excellent too................but can be problematic............
look for anything with aperture-grille, and perfect flat technology..............
lets be honest, even the worse crt monitor is still MUCH MUCH better than the most expensive LCD monitor........
I dont like saying that all lcd monitors are rubbish, but the facts are, they are.........LCD is the most pixellated tech you can get, and the lcd refresh will always be slow, on such large panels............
avoid like the plague.............
ag studios is offline   Reply With Quote
Old 01-04-07, 04:58 PM   #8   |  Link
homerrulez
where you been my whole life. I had to spend 600 dollars on an fpd2185 to only figure out its garbage. Text and some picsmay be sharp but when you notice that purple on an sdtv is grayish white on the left side then its time to smack this crap of an lcd and give it the boot! Man I wish I had saved up my money and went with CRT. I knew they were of better quality but figured why not give the LCD a try, 1000:1 contrast ratio sems pretty good for LCD. Well its still crap . Ok any ideas if the P225F is a good monitor. I have a chance of buying that one local right now but have to decide before driving and buying it!
Old 01-06-07, 01:05 AM   #9   |  Link
Apache137
so a LG 30" slimfit 1080i wouldnt be a good choice for a monitor??
if not, why?
i dont know much about this stuff.
thanks in advance,
Apache.
Apache137 is offline   Reply With Quote
Old 01-09-07, 04:20 AM   #10   |  Link
homerrulez
yea I would like to knwo too as i am trying to save some cash here
Old 01-18-07, 01:04 AM   #11   |  Link
S. Hiller
An interlaced display might be pretty hard on the eyes for use as a computer monitor. Also, the true resolution of a 30" CRT HDTV (with the exception of some out of production Sonys) is only really about 800 pixels across from what I understand...
S. Hiller is offline   Reply With Quote
Old 01-18-07, 04:57 AM   #12   |  Link
drogulus
The P225F uses the Mitsubishi Diamondtron tube with .24 pitch, the same tube used in the Mits Diamond Pro 2070, one of the best CRT monitors ever built. I don't know if the Viewsonic is of equal quality, but it might very well be close. I have the 19" Diamond Pro, and I can tell you that watching 1080P HD video clips downloaded from the Windows HD site is quite an experience!
I hope there are still monitors like this available from somewhere when mine finally quits.
__________________
ernie
drogulus is online now   Reply With Quote
Old 01-18-07, 12:24 PM   #13   |  Link
danedrow
New Member
Finding CRT's
Totally agree with everyone on the benefits of CRT's over LCD for a monitor. I won't get an LCD because I run my games at higher resolutions than I like to run my desktop. That's why I still have my 5yr old viewsonic A95F sitting on my desk.
As for finding a new CRT, check out the viewsonic website. They continue to make CRT's for computers at a decent price ~$250 for a 19" model, and they have the ever popular dealer finder, since the big box stores only carry crap CRT's now.
danedrow is offline   Reply With Quote
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.18881106 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
