AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > Video Components > Cable, Digital Cable - Non-HDTV
Forum Jump
Old 01-03-07, 10:14 PM   #1   |  Link
SuperAmmo
Widescreen SD? Is it possible?
Always wondered if this was possible. This way when watching an SD station, the image wouldn't have to be stretched or have the letterbox bars or having to use the zoom function. It'd work similar to how HD and SD work right now so that a 4:3 TV wouldn't be screwed, they just wouldn't see the full image like someone with a 16:9 TV would.
Although I'm sure if it was possible, it would have been done by now...
EDIT: I'm NOT talking letterboxed, FYI.
SuperAmmo is offline   Reply With Quote
Old 01-03-07, 11:01 PM   #2   |  Link
gjlp
SD Widescreen - totally possible
The United Kingdom has had most of it's new TV programming for the past several years created/broadcast in widescreen even though HDTV has only become a reality there in the last few months. It really frustrated me, moving to the U.S. and seeing the resistance to moving towards 16:9 digital broadcasts (apart from HD).
gjlp is offline   Reply With Quote
Old 01-05-07, 01:12 AM   #3   |  Link
humdinger70
It's been going on (widescreen SD) for several years. It's called Major League Baseball on Fox!
humdinger70 is offline   Reply With Quote
Old 01-05-07, 09:56 PM   #4   |  Link
GeekGirl
Señora Member
During that time frame, the NFL on Fox also did line-doubling SD with wide screen formatting for their HD broadcast.
GeekGirl is offline   Reply With Quote
Old 01-06-07, 10:06 AM   #5   |  Link
kenglish
16:9 Standard Definition is possible....we've been doing it for years. Problem is, the CE industry doesn't recognize it, for the most part, as a standard (so much for "standards" ).
I can't seem to find a 16:9 SDTV set anywhere, and the last couple of STBs I've purchased don't have a setting for displaying 16:9 SD on a 4:3 screen. Needless to say, I don't make recommendations on STBs or sets much anymore.
__________________
Ken English, Sr. Engineer, KSL-TV/-DT.
"Not a REAL Engineer, but I play one in TV"
kenglish is offline   Reply With Quote
Old 01-06-07, 01:37 PM   #6   |  Link
John Mason
Quite a few PBS presentations are in WS 480i. Usually they tell you so at the beginning of the program or list them as WS instead of HDTV. Sometimes, depending on the quality of the images, it's possible to mistake programs as HD. Waiting for segments that show distant fine details helps determine it's 480i (possibly upconverted) because distant objects aren't detailed enough (if your display can present finer resolutions.) -- John
John Mason is offline   Reply With Quote
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.11713696 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
