#1 | Link |
New Member
Speaker Wire Polarity Question From A Newbie
Just checking to make sure...
I bought some 16 guage Monster speaker cable that has the clear coating on it. There's writing in white on one side and none on the other. The side with the writing should be the negative, correct? |
#2 | Link |
as long as you keep the side with writing consistent with the output from the receiver/amp to that of the speaker (eg black with black, red with red). So if the you use the writing side as negative (black) just ensure that it is used that way throughout. If you are using bananna plugs it will make things much easier to identify.
#3 | Link |
Head-Spinning Good!
As a newbie, let me also bring this up for you ... you overpaid for ordinary cable. Unless you bought it at some store's cost price (a tenth of the MSRP, I hear!) Monster is absolutely not worth MSRP. Or anything remotely close (15% or higher)
If you still can, go return it to the store and pick up some RadioShack or HomeDepot generic speaker cable.
__________________
*ashu* |
#5 | Link | |
Head-Spinning Good!
Considering your original question, and now that piece of information about your employer ... too many jokes, that I would get banned fo making
![]() Suffice to say THIS is Precisely why the rest of the world should buy cables from monoprice/bluejeans etc ...
__________________
*ashu* |
#7 | Link | |
Mr. Misrepresented
Great response on your part LOL.
__________________
The First Clarke Law states, 'If an elderly but distinguished scientist says that something is possible he is almost certainly right, but if he says that it is impossible he is very probably wrong.' |
#8 | Link | |
Head-Spinning Good!
And I doubt he made up that response. he doesn't work in AV & BestBuy, and doesn't trust those folks either. Smart move ![]()
__________________
*ashu* |
#9 | Link | |
Mr. Misrepresented
__________________
| Bookmarks |
| Thread Tools | |
