AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > Video Components > Cable, Digital Cable - Non-HDTV
Forum Jump
Old 01-04-07, 09:09 AM   #1   |  Link
s76helipilot
New Member
comcast dvr code for sammy?
Does anyone know what code will work for my Samsung HLS5687 remote to run my Comcast HD DVR STB? It is a Motorola. I tried 000-074 last night like the Motorola instructions say but still could not get it to work. The list shows the correct code as a 064.
s76helipilot is offline   Reply With Quote
Old 01-04-07, 06:44 PM   #2   |  Link
GeekGirl
Señora Member
I don't have my remote setup for my STB, but my Sammy HL-R6768W doesn't list Motorola for cable boxes. However, it does list General Instrument (054), which is now Motorola. Try that. Hope that helps.
You should also check out the Sammy thread for your display: http://www.avsforum.com/avs-vb/showthread.php?t=665890
GeekGirl is offline   Reply With Quote
Old 01-06-07, 10:16 AM   #3   |  Link
dodge_ram
New Member
Try this
I had the same problem. However, I tried something else and it worked. Hope this helps you.
I programmed the remote using "Cable" instead of "STB", and use the code "041" for "GI".
dodge_ram is offline   Reply With Quote
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.09796000 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
