AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > Display Devices > Direct View (single tube) CRT Displays
Forum Jump
Old 01-04-07, 11:57 PM   #1   |  Link
reduno
Small TV for PS2
I am looking for a small TV (<= 20") for the kids to use with their new PS2, so I can claim our main 32" Sharp back. I have been looking at the 16" Samsung TX-R1635 and the 20" Magnavox 20MT4405 among others. I would like to stay below $200, including an extended warranty. Any comments or suggestions?
Thanks, Red.
reduno is offline   Reply With Quote
Old 01-05-07, 02:00 AM   #2   |  Link
King-Reyes
I'd say go to wal-mart and buy http://www.walmart.com/catalog/produ...uct_id=5273237
King-Reyes is offline   Reply With Quote
Old 01-05-07, 02:20 PM   #3   |  Link
reduno
Thanks for the suggestion. I had some concerns about the LCD response time fro games (16 ms) and the scaling to 768 lines. The PS2 will at least give a clean signal for scaling. Also when I add shipping and the extended warranty, I will be over my target price point.
Thanks, Red.
Old 01-05-07, 08:31 PM   #4   |  Link
adavis720
My advice would be to go with whichever brand name CRT is on sale that week. Component video is a plus if you have the component adapter for the PSII.
Which store is closet or most convienent to you?
Here a couple just to start, I don't think you will see a HUGE difference from TV to TV in that size/price range.
Best Buy has the Samsung TXR2035 for $175.95 ($190 w/ tax). (Flat Tube 20 inch w/ component input)
Walmart has an RCA 20F420T. I got that one for my Mom when her little bedroom TV died. It's got a nice picture for $115.00. (Flat Tube, No component video.)
adavis720 is offline   Reply With Quote
Old 01-09-07, 10:55 AM   #5   |  Link
Penarin
Go with a standard def CRT. For games, don't go below 20 inches. Flat tube (not flat screen) would be nice, and the PS2 over component does look great- not sure if the kids would notice though.
The Sammy in the above post looks pretty good to me.
Penarin is offline   Reply With Quote
Old 01-10-07, 11:41 AM   #6   |  Link
cocoasprinkles
S-Video is a huge improvement if you have been using regular yellow cable until now. For the kids if u want to save a buck or two and maybe buy them the S-Video cable don't worry about component
cocoasprinkles is offline   Reply With Quote
Old 01-10-07, 12:31 PM   #7   |  Link
reduno
Thanks for all the comments. I will definitely make sure the set has component or S-video input capability. Locally we have Target, Walmart, Sears and Best Buy (Circuit City is a little further). I checked the local Best Buy on Monday and the CRT selection was very limited. They only had 4 boxed sets in the 20" and under range (2 Toshiba 20AF45 and 2 Insignia DVD combos). They still had some other models on display (mostly Insignia) but no stock (I even asked). No sign of any smaller sets with digital tuners. I could order on-line but I would rather see the set first and avoid shipping charges.
Regards, Red.
Old 01-10-07, 02:26 PM   #8   |  Link
Bill1313
Myself, If you don't need an ATSC Tuner, I would go with one of the cheaper 24" Flat Tube sets because there not that much more but the picture is soooo much bigger especially if they have been using a 32" set a 20" or smaller set is really going to look small.
Bill1313 is offline   Reply With Quote
Old 01-10-07, 03:25 PM   #9   |  Link
InYourEyes
Toshiba 37LX96 LCD
If you don't mind a 27", check out the Orion TVD2710 CRT SDTV at Wal-Mart for only $150 right now. Orion is made by Toshiba. Your kids will love the 27" size and the picture quality looks pretty good. It has component input.
InYourEyes is offline   Reply With Quote
Old 01-15-07, 11:51 PM   #10   |  Link
reduno
Thanks to all the suggestions. While looking around, I came across a tuner box that allows a TV signal to be displayed on a computer monitor. Since I had an old CRT monitor already, I gave it a try as a low cost alternative. I had to take the monitor cover off and adjust the color, as everything was green at first. After tweaking, it actually looks pretty good and probably has a finer dot pitch than a TV of the same size (14").
Being a CRT, I was able to use 640x480 resolution, so no scaling and just a conversion to 480p. We may get a larger TV in the future but this set up seems to be keeping the kids happy for the moment.
Thanks again, Red.
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.14331889 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
