#1 | Link |
New Member
A little confused?
A little advice would be appreciated. i am intereseted in going Hi-def.
Currently have a HS50 from Sony. Which is a native 1280 720 PJ. It says it can accept 1080/24PsF What is this and is it better than the 1080/50i signal that I am currently feeding it. Confused ??? Thanks Tariq
__________________
Tazpc |
#2 | Link |
If you're projector can do 1080p/24fps (frames per second), then frame rate conversions can be skipped when sourced by either HD DVD or BD playing material encoded as such (native frame rate for film is 24fps). The advantage is not spatial (ie. resolution, geometry, etc. of the image you see), but rather temporal (how the individual frames are displayed to make motion possible). With a 1080i/50 signal, a conversion must be done to go from 24 progressive frames to 50 interlaced fields (25 frames) which adds lots of "time distortions" expressed as blurry movements, judder, and other artifacts.
In other words, you're getting "mechanically" closer to how the film is shot and presented in a theater: at its native frame rate and in high-definition resolution. To quote that hag Martha, "it's a good thing!" ![]() Last edited by marcusm750; 01-05-07 at 09:59 AM.. |
#4 | Link | |
#5 | Link | |
#6 | Link | ||
#7 | Link |
New Member
24 PsF stands for 24 Progressive segmented Frame. It is 24 frames per second but
each frame is split into 2 halves. To me it sounds like interlaced but, according to people who understand it better than me, it's different. It was popular a couple of years ago. When the Sony Qualia projector came out this was the only type of 1080 signal it could accept. You don't seem to hear about it much anymore. |
#8 | Link | |
| Bookmarks |
| Thread Tools | |
