AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > Video Components > Cable, Digital Cable - Non-HDTV
Forum Jump
Old 01-06-07, 04:52 PM   #1   |  Link
squale
Can you make a wired coax cable into wireless?
I have a bedroom where the cable jack comes out of the wall on the oppostive side of the room from where I want to put my tv. I don't want to room coax cable all the way around my room. Is there a device where I can plug into the coax coming out of the wall and it will wirelessly transmit the cable signal across the room to the tv?
squale is offline   Reply With Quote
Old 01-06-07, 05:27 PM   #2   |  Link
bfoster
No. You could put a cable box where the cable is and try one of those "rabbit" things, might work being in the same room.
bfoster is offline   Reply With Quote
Old 01-06-07, 05:33 PM   #3   |  Link
squale
what do you mean "rabbit" things? do you have a link?
Old 01-06-07, 06:03 PM   #4   |  Link
bendog2784
Yes they make wireless video transmistters. Depending on your setup, something like this http://www.avdeals.com/transmitters.htm may or may not work for you.
bendog2784 is offline   Reply With Quote
Old 01-06-07, 07:01 PM   #5   |  Link
bfoster
Bendog2784's link is exactly what I was referring to. It is a wireless link for a single Audio/video source, such as a cable box output.
Old 01-06-07, 07:05 PM   #6   |  Link
squale
why do I need a cable box, can't I just attach one of these things to the cable coming out of the wall and change the channels on the tv like I always do?
Old 01-06-07, 07:18 PM   #7   |  Link
SAAudio
No, it does not have a tuner in it. You must use a tuner to decode the channels. This is why you must either
1. Get a cable box (tuner) and connect it to wireless video transmitter
2. Run coax directly to tv, using tuner in TV.
No other way that I am aware of.
SAAudio is offline   Reply With Quote
Old 01-06-07, 08:16 PM   #8   |  Link
wrwine3
Or you could use a VCR and save the rental fee of the cable box..
wrwine3 is offline   Reply With Quote
Old 01-06-07, 08:43 PM   #9   |  Link
SAAudio
Yep, that would work too.
Sometimes I speak without thinking.
Old 01-06-07, 09:57 PM   #10   |  Link
AntAltMike
These wireless transmitters can only transmit one tuned channel at a time, so in addition to the Rabbit or whatever transmitting an audio-video signal from one room to another, an arrangement must be made for your remote control to change channels on the tuner. Some wireless A/V transmitter products have the capability to support the remote control, but others do not.
AntAltMike is offline   Reply With Quote
Old 01-06-07, 10:21 PM   #11   |  Link
miniz
OFFICAL HOME OF HDTV
Why don't you just fish a new coax or re-arange your room? The video senders are generally junk and a short-term fix.
__________________
"PLEASE HELP STOP HDTV ABUSE! FEED YOUR HDTV AN HD SIGNAL!"
miniz is offline   Reply With Quote
Old 01-07-07, 02:29 PM   #12   |  Link
hometheaterguy
I agree, retro a new line to your new location. If you do not have glowrods or fishtape for an internal wall fish from an attic, unfinished basement, or crawl space, run it exterior. Depending on your service, (cable or satellite) they may be able to do this for you reasonably and in new connects/new installs or a mover installation it could possibly be for free.
hometheaterguy is offline   Reply With Quote
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.14971399 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
