AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > Video Components > Cable, Digital Cable - Non-HDTV
Forum Jump
Old 01-07-07, 02:06 PM   #1   |  Link
LtCarter47
4:3 programming gets stretched
My brother has a Sony KDF-E50A10 Rear projection LCD and uses a Motorola 6412 with component cables. He's had this setup for about a month now, and this issue has just come up today after a power cycle on the 6412. Basically what has happened is he has lost his "Normal" in the wide mode menu, so any 4:3 channel he watches is automatically set to "Full", and he can change it to anything but Normal. All his other video sources seem to behave normally.
He talked with a Sony rep, and after some troubleshooting he decided it must be a problem with the comcast box, because other components, like the DVD player, don't have this problem.
What I tried was unplugging the 6412, swapping the cables to a different component input, and tried the HD zoom button on the Comcast remote. Nothing worked. For now I've told him to plan on swapping out the 6412 for a different one on monday, but I thought I'd check in with the experts here and see if anyone had an idea what the problem is, and hopefully a fix.
Sean
LtCarter47 is offline   Reply With Quote
Old 01-07-07, 05:21 PM   #2   |  Link
miniz
OFFICAL HOME OF HDTV
swap box then report back. I had an SA box do this recently.
__________________
"PLEASE HELP STOP HDTV ABUSE! FEED YOUR HDTV AN HD SIGNAL!"
miniz is offline   Reply With Quote
Old 01-07-07, 07:36 PM   #3   |  Link
Mallego
Just go into the service menu and reset it to what you like. Leave TV set on, turn off box and hit "Menu" You can set TV type, output resolution and how the box output a 4:3 picture.
Mallego is offline   Reply With Quote
Old 01-11-07, 11:37 AM   #4   |  Link
LtCarter47
Thumbs up
Yup, that did the trick. I would have gone into the service menu as Mallego suggested, but didn't get a chance to get to his house this week.
Sean
Old 01-11-07, 02:38 PM   #5   |  Link
miniz
great! Sometimes these boxes have currupt firmware.
__________________
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.10201907 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
