AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > Video Components > Cable, Digital Cable - Non-HDTV
Forum Jump
Old 01-08-07, 01:46 AM   #1   |  Link
intertan
s-video to dvi?
I got a 19" lcd monitor for christmas. It has a vga and a dvi connection, I would like to take it with me when I go to school, and have my xbox 360 using the vga connection and my ps2/original xbox using the dvi connection. is there a cable/device to convert it from s-video to dvi? or possiblty to vga then the dvi adapter.
on another subject does anybody have a tv tuner card for there pc that has no delay issues? like when you jump there isn't a second before you jump on the screen.
intertan is offline   Reply With Quote
Old 01-08-07, 09:56 PM   #2   |  Link
GeekGirl
Señora Member
My video card has DVI to VGA adapter- that's easy. There are also VGA to S-video / RCA adapters, used for video card outputs. Here's an adapter: http://www.monoprice.com/products/pr...ormat=2&style=
Caveat: I don't know if the pinout for going in the "other" direction, S-Video to DVI. In other words, is it a simple wiring connection or is there something else inside?
GeekGirl is offline   Reply With Quote
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.09087300 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
