AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > Home Entertainment & Theater Builder > Theater Room Items & Accessories
Forum Jump
Old 08-06-07, 12:20 AM   #451   |  Link
Yogi69
After many hours of fiddling - it all worked out. It took so long as I agree so much Pacific Ocean and so little land makes it less obvious that it is the earth - I tried to have an each way bet.... Hopefully when I put it to music It will be OK.
Yogi69 is offline   Reply With Quote
Old 08-06-07, 04:24 PM   #452   |  Link
Deane Johnson
I never expected my 72 year old brain to be able to do the first thing with the Universal opening in Blender, but thanks to this thread and Mike Falz's generous sharing of his template file, I had complete success in one afternoon. Incrediable.
One thing remains. How do I get the logo music off this site in a usable form?
http://www.reelclassics.com/Gallery/music26.htm
BTW, I'm not using mine for a theater opening (that may come later). I'm using it as an opening for my home videos. I edit in Grass Valley Edius professional video editing software.
I'm assuming if you wanted to use this for a feature film opening in a home theater, and have it edited right up in front of the movie start, one would have to use an HTPC, is that correct?
Deane Johnson is offline   Reply With Quote
Old 08-07-07, 02:50 AM   #453   |  Link
Yogi69
Hi Deane, I am at work right now and the "netnanny" won't allow me to download mp3 files
Have a look at the other thread http://www.avsforum.com/avs-vb/showt...x#post11159048
When making the Fox intro I used AVI-Mux (freeware) to add the .ac3 audio file and it worked fine.
Old 08-07-07, 06:27 AM   #454   |  Link
Deane Johnson
Thanks, I got it. Rather simple. Just right click on the musical note and use "save link as". I just had never need to know how to do it before.
The MP3 file works perfect in my Grass Valley Edius software, so I don't even need to do a conversion. I can then time the video with the music and export in any form I want. Edius allows me to slow down or speed up the video track to make it all come out timed perfect with the audio. I wanted the "in high definition" to hit right on a music stab.
Old 08-07-07, 09:54 AM   #455   |  Link
Deane Johnson
New problem.
I had a highly successful rendering of the clip. Smooth as glass. Then, I decided to do an additional clip with "in widescreen" instead of "in high definition". I made a copy of the original, changed only the bottom line and did a render. The whole thing plays back with some little jerks in the flow. All sections, the earth rotation, the lettering jerk together, so it must be the entire playback, not just a single element.
Any ideas what created this issue?
Old 08-07-07, 01:10 PM   #456   |  Link
rgroves
On the Universal Into video, and the MP3 file, I had to cut off hte first 2.5-3 seconds of silence from the file. Actually I think I got rid of all of hte lead-in silence on the MP3. That had my "Feature Presentation" and the music queue hit almost perfectly. I think there is a .1 second difference, but it's good enough for me.
Not sure on the jerky clip....are you looking at the RAW output AVI file, ro has it been encoded with a codec?
rgroves is offline   Reply With Quote
Old 08-07-07, 07:27 PM   #457   |  Link
BSpielbauer
Originally Posted by Deane Johnson
New problem.
How exactly are you playing back the file? Is it on a PC or an HTPC? The reason I ask -- I have found that sometimes I will see jerky playback on my PC, and it seems to be due to the system resources available at the time. I have seen a lot of video clips that played fine one day, and then exhibited "jerky" and choppy playback the next. A re-boot seemed to solve the problems. And, I have seen this with four different software players (Windows Media Player, Nero's player, the ATI player that came with my video card, and Windows Media Classic.
I have then burned the result to a DVD, and noticed that the results came out fine.
If none of this applies to your situation, just ignore my entire reply.
-Bruce
-Customized Home Theater Intros on DVD: http://www.S2Digital.com
BSpielbauer is offline   Reply With Quote
Old 08-07-07, 07:54 PM   #458   |  Link
Deane Johnson
I was just clicking on the avi file and letting the Windows Media Player play it. Maybe you've hit it the problem. Yes, it's on a PC. Dell Pentium IV, 3.4 mHz, 4 gig ram.
Old 08-08-07, 08:07 PM   #459   |  Link
teknoguy
AV apprentis
Originally Posted by rgroves
Try opening blender by itself, hitting F9 and seeing hte Shapes tab is there. Then open the file.
Been out of town for a few days and just got back to this...
rgroves, many thanks for the hint of opening Blender first. It worked!!
Finished the edits and I'm rendering as I write this.
-t
teknoguy is offline   Reply With Quote
Old 09-05-07, 11:43 PM   #460   |  Link
kezug
Guys, I am trying to add text to the Universal Studio blender file. I am following the instructins provided, but I am stuck here:
• Back in the Shapes Tab, left click on the bar next to the 1.00 (it should stay at 1.00, but this will add another key frame).
For the life of me, I can not seem to get this to work. Please what do I need to do. Where next to the 1.00 do I left click? What should happen? Does 1.00 highlight as if in edit mode? If so, then what?
FYI: I am using the latest Blender...just downloaded today
My latest attempt is this...when at frame 270, my title text is layed out flat as it should, then the world should just spin for the remaining frames...however, from frame 270 on, my text "left and right ends (if that makes sense) begins to stretch (wrapped effect) to the back side of the world. I am certain the step above that I listed is where I went wrong...help!
kezug is offline   Reply With Quote
Old 09-06-07, 09:26 AM   #461   |  Link
MikeFalz
Hi Kezug,
Got your PM. I'll respond here in case someone has the same issue.
First, you may want to start fresh from the original file in case you have an extra key frame in there somewhere.
With the shapes tab slider you are creating key frames. The first is at frame 1 with a value of 1.00. This means the text should be curved at frame 1. The next is at frame 180, again value of 1.00. This means the text should stay curved from 1 to 180. The next is at frame 270, a value of 0.00 (or straight). This means the text should gradually move from curved to straight between frames 180 and 270. If there are no more keyframes, the text will stay straight for the rest of the animation.
If this is the step that is tripping you up...
· Back in the Shapes Tab, left click on the bar next to the 1.00 (it should stay at 1.00, but this will add another key frame).
... then for this step, drag the bar to zero and back to 1.00 again before switching frames. This will accomplish the same thing.
I suspect you have another 1.0 key frame later in the animation which is causing it to curve again.
Good luck,
Mike
__________________
"You need people of intelligence on this mission. . . quest. . . thing."
MikeFalz is offline   Reply With Quote
Old 09-07-07, 07:43 AM   #462   |  Link
kezug
Originally Posted by MikeFalz View Post
Hi Kezug,
Good luck,
Mike
Thanks Mike....it works now.
Now my current issues: 1) no sound...how do I add the sound?
2) Playback on 1 pc is excellent, playback on my other pc is bad...video skips and stops. Same ver of quicktime. I have no idea what to do. Of course, the PC with problems is the pc I need to work! (NOte: I did Codec: QuickTime:Animations at 30fps for best quality)
Furthermore: The pc that isnt working 1st had QuickTimeAlternative installed, then I installed Quicktime afterwards. I then uninstalled QTAlt, then QT and reinstalled QT...Iwonder if there is still something lingering around.
Old 09-07-07, 07:56 AM   #463   |  Link
rgroves
The output from blender is a very large file. You'll need to run it through another app (read through the thread as there are several mentioned, and I can't remember the names of them right now). I bet the file you're trying to view is several hundred megs in size. After I worked on mine is was 800+ MB, but only 3 MB after I reconverted it and added the audio.
There are also the links to the audio clip to add to the file in this thread.
Old 09-07-07, 02:01 PM   #464   |  Link
kezug
Thanks rgroves. You are right, my file is 800MB. I will read through this thread again for audio and video tips to clean this up.
Old 09-07-07, 02:26 PM   #465   |  Link
rgroves
On the audio - try to get the .ac3 version (5.1 surround) and will sound 1000% better than an MP3 or WAV. You'll need a better program to process the AVI and AC3 file together.
I think I ran my through Movie Maker that's part of WinXP, but it was only to see if it came out right.
Now the Disney intro (not sure if it's in the thread or another), the sound is fantastic and almost blows us off the couch if I forget to turn down the volume.
Old 09-08-07, 04:45 PM   #466   |  Link
kezug
Ok, first of all, kudos to all of you that have provided help here and have shared your experiences. Hats off to those who can do blender from scratch.
I have finally got to the point where all I have left to do is one last thing. I took the Universal Studio blender file and updated to my wording . Output was done in AVI-Codec Default 852x480
I extracted the audio (using DVD Audio Extractor) for Universal Studio(from Casino), myself .
I then combined video and audio (using AVI-Mux GUI) .
Now I am left with an 800+MB file .AVI that plays beautifully on my Core 2 Duo XPS 410. However, it stutters on my laptop (which is what I need to have working)
I downloaded AVI DeMux, but here I am left clueless as to get this final rendition compressed. What do I need to do in AVI DeMux to get this compressed with good quality! Or should I be using some other software to compress?
Old 09-08-07, 06:35 PM   #467   |  Link
teknoguy
AV apprentis
Congrats!
I wouldn't worry about the playback on your laptop. I'm sure it will, once put into a DVD format, play stutter free.
Can't help you with the AVI DeMux...never heard of it myself.
You don't have a DVD burn software like Roxio or Nero?
-t
Old 09-08-07, 07:11 PM   #468   |  Link
kezug
Originally Posted by teknoguy View Post
Congrats!
-t
Thanks. I did just that, used Windows DVD Maker. I didnt like how it forced the DVD Menu or only non-menu option was continuous loop. So I just took the VOB file that matched my Intro and put that on my laptop. Now I have a compressed Intro of about 23MB instead of 800MB and the quality is very good.
Awesome, just awesome.
Now I need to find me some high quality (lets all go to the lobby) intros and other stuff too.
Old 09-09-07, 11:57 PM   #469   |  Link
kezug
I would like to have my version of the modified blender for the Universal Studio intro show the "glow" behind the earth right when the music hits at the time the 2nd line of text appears. However, I can find the 2 circle objects that represent that effect, but I just cant figure out how to change the timing from the frame those circles will appear.
Can anyone offer some tips on what to adjust to make this happen?
Old 09-10-07, 10:20 PM   #470   |  Link
kezug
bump..anyone?
Old 09-11-07, 09:03 AM   #471   |  Link
SuperTal
Look Up!
Anybody have a sample .mov? I'd love to see this?
I may have to download Blender and make one for MyPreMovie...
__________________
My new site is up: http://www.MyPreMovie.com/ - the ultimate in pre-movie showing, it's a fun hobby!
SuperTal is offline   Reply With Quote
Old 09-11-07, 09:15 AM   #472   |  Link
tlogan6797
kezug -
When I aplied the universal ac3 file to the resulting avi file, the timning was already perfect. I didn't do anything other than what is already in all of the instructions found here.
Tom
__________________
Tom Logan
Need motivation? Get LOGANED
An as-yet un-named theater designed by Big-WarrenP-BritInVA
tlogan6797 is offline   Reply With Quote
Old 09-11-07, 10:53 AM   #473   |  Link
ssdesigner
help?
Thanks to Mike for the GREAT tutorial, FANTASTIC work!!!
Ok, so I've done this several times now and I'm not quite sure where the SQUASH is happening, but as you can see, my version gets SQUASHED horizontally when I output the final file:
http://www.youtube.com/watch?v=WPagxZ4Ozx4
It looks like it's still 16:9 in DVD-Lab Pro2, but when it gets output it's not quite right. Anyone else come across this? I use DVD-Lab to combine the ac3 audio file and the .vob file together....is there a setting i'm missing??
-Ss
ssdesigner is offline   Reply With Quote
Old 09-19-07, 11:27 PM   #474   |  Link
mike stewart
New Member
hi all,
i'm new here and just started using blender. i was able to do the fox intro, but i'm having a difficult time doing the universal and i wanted to be able to use it this weekend. any help would be appreciated.
trying to put:
ULTIMATE SOUNDS DJS
tnx in advance.
mike
mike stewart is offline   Reply With Quote
Old 09-21-07, 05:15 AM   #475   |  Link
mike stewart
New Member
i got it, tnx anyway.
mike
Old 09-21-07, 02:29 PM   #476   |  Link
MikeFalz
I've been getting a few e-mails lately from folks lookiing for help, so I'd thought I'd give this a bump...
I've created a new blender file with and some step by step instructions to customize it.
Template -
http://falzonvideo.com/vid/UniversalNewTemplate.blend
Instructions -
http://falzonvideo.com/vid/Universal...structions.doc
Good luck!
Mike
__________________
Old 09-22-07, 08:02 AM   #477   |  Link
kezug
First, make sure you are following the instructions precisely...but let me guess, are you stuck here:
This had me messed up for a while. You must always start completely over with the original when you mess up. Keep that in mind.
As for that step above. I am still not sure how I got mine to work, but it does, just keep at it and you will get it to work...eventually.
Old 09-23-07, 11:43 PM   #478   |  Link
newby32
New Member
removing the stars
How can I remove the stars in the back of universal animation. Any help is appreciated, and thanks.
newby32 is offline   Reply With Quote
Old 09-29-07, 04:12 PM   #479   |  Link
TECHJPM
New Member
Could someone help please...
I have tried reading through these forums, but can't find the info...
I have toyed with blender, but can't figure out how to do the final saving, or rendering to do the save....
I have gotten it to render 1 part of the scene...
I am using the final death star one....
Wanted to use the one with the explosion, but it isn't available....
Please steer me in the path to get it to be a avi, or something similar...
TIA...
TECHJPM is offline   Reply With Quote
Old 11-08-07, 08:30 AM   #480   |  Link
djb61230
Technical Wizard
Thank you so much for the information and Blender file available in the thread. Adding this to my home theater setup adds that extra something that is just so cool.
And to be able to do this on Linux and MythTV is just awesome. When all is said and done my intro AVI file is 15 meg, looks and sounds great as I was able to get the AC3 audio from one of my own DVD movies (Field of Dreams).
Thanks again as the hard work was creating the Blender file and offering directions on how to customize it. The rest of the Linux stuff was easy for me, no way I would have this without the kind people in this thread!!
If anyone needs help getting this going on Linux or MythTV or anyone wants the AC3 file, PM me or ask away here.
djb61230 is online now   Reply With Quote
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.35589910 seconds (100.00% PHP - 0% MySQL) with 10 queries
Copyright ©1995 - 2010 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
