#1 | Link |
New Member
Hookup methods for Local OTA HD with Direct TV
Hi,
I have a question. I have direct TV with the standard receiver. I have a HDTV and would like to get local channels in High Def. Is there a way to mount an antenna in the attic or on the roof and use Direct TV's cables to run the HD signal in to my TV? Would I have to have a HD receiver are are there ways to use splitters and carry two signals on the same cable? Thanks for your help. Chris |
#3 | Link |
Just another member
You can use diplexers on each end of the run to join then split the OTA signal and Directv signal. You of course need an ATSC tuner to tune digital OTA broadcasts also.
__________________
Matt Please don't PM me with technical questions that should be posted in the forum. |
#4 | Link | |
Just another member
From the PM I received.
Diplexers look like splitters with one side marked satellite and the other marked OTA. There is an example of one here with a diagram of how they work - http://www.solidsignal.com/prod_disp...p?prod=SPDX100 If you list the make and model of your TV, we can help determine if it has a tuner in it if you are not sure.
__________________
#6 | Link |
This diplexing approach works well for the round dish or the 3-lnb dish but will not work if (when) you move to the 5-lnb dish - actually it will work today but as soon as the new DirecTV 10 and 11 satellites start transmitting later this year the diplexing scheme will fail. This is because these two satellites will generate signals which will come from your dish on the "b-band", this frequency band overlaps OTA so you won't get either the new satellite signals or OTA, they will interfere with each other.
Just bear that in mind when (if) you consider moving to DirecTV HD...... |
#7 | Link |
New Member
Not having any luck?
I got my Exterior antenna for HD and hooked it up inside and it worked great. It was against my front door on the floor! I was looking forward to even better results when I moved it outside. Inside, I hooked directly to the air in on my TV. Outside, I used two diplexers and ran it in on my Direct TV cable and it's almost like I don't have an antenna. What's the problem??? Do Diplexers work in reverse? (On the Direct TV end) I can't believe I am loosing that much signal running in on the same wire my Direct TV runs in on. (approx. 50' more) The only thing different now is additional coax, and two diplexers...already mentioned. Is there a fix???
Thanks, Chris |
| Bookmarks |
| Thread Tools | |
