#1 | Link |
New Member
Rolling Bars when I connect Cable
Hi,
I'm seeing, for lack of a better term, rolling bars running vertically on my screen when I connect my cable through DVD player (built in tuner), or my VCR. My first thought is to try an in-line noise filter from the coaxal to the tuner. My next guess would be clean the power up with a surge protector with somekind of conditioner. All the cables have been tested on other systems with no problems. The DVD player shows a perfect picture until I touch the coaxal cable to it. Any other reccomendations would be great or thoughts on my first two options. Some basic system info as follows: Optima Projector displaying 120" screen Pioneer A/V receiver - Midlevel 7.1 with all the in and outs you need Panosonic DVD with built in tuner Basic cable service (not digital) Running Coaxal to DVD - Component from DVD to Receiver - Component from Receiver to Projector. |
#2 | Link | |
#4 | Link |
In another thread, the poster disconnected the cable ground and the problem disappeared. He knew then that the problem was the cable company. This may save you some bucks if the conditioners, etc., are expensive. Then, hook ground back up and call company like above poster said. If not fixed, ground loops can be a pain in the neck. You will have to start isolating each component to find the bad one. If possible, hook up all component grounds to the same ground. If the ground loop is inside your house, it may be from using two different ground wires. Another poster mentioned the two different ground wires may have different potentials (something about ohms law creating resistance?)
#5 | Link | |
OFFICAL HOME OF HDTV
ground loop.
Why o' why do you have a 120" screen that doesn't have any HD content available? Wow, that must look just horrible. I couldn't even imagine how bad that must look.
__________________
"PLEASE HELP STOP HDTV ABUSE! FEED YOUR HDTV AN HD SIGNAL!" |
#6 | Link | |
Why o' why do you obsess about everyone's HD? You worry about you and keep the threads "on topic". ![]() |
#7 | Link |
I honestly don't know how anyone could stand watching a 120" analog image. I can hardly stand it on a 27" TV.
Thank you for nit-picking Ratman, once again. You never fail to take the opertunity to up your post count.
__________________
#9 | Link |
Your continual obsession with criticizing me, with the sole intention of upping your post count is becoming old. Now go have some fun with Windows 95 and stop posting, just to post.
__________________
| Bookmarks |
| Thread Tools | |
