AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > Home Entertainment & Theater Builder > Theater Room Items & Accessories
Forum Jump
Old 01-11-07, 09:28 AM   #1   |  Link
Josh Z
Cranky Member
"Now Showing" and "Coming Soon" graphics?
Does anyone have links to good, printable graphics saying "Now Showing" and "Coming Soon" that I can attach to a display stand in my theater? Don't need to be large. It's just a stand that holds up a DVD case.
I have zero graphic design skills or I would try to make something myself.
__________________
Joshua Zyber
Critic, High-Def Digest
Contributor, Home Theater Magazine
Curator, Laserdisc Forever
My opinions are my own, and do not necessarily reflect those of my employers.
Josh Z is offline   Reply With Quote
Old 01-11-07, 01:09 PM   #2   |  Link
victor-eyd
Quad Yeah!
This is what I did . I work at a picture framing shop so I simply used Word and printed out "NOW SHOWING" in a fairly large and nice looking font on really glossy photo paper. Then I took the sheet and had them make me a silver mat with an opening for the text.
I then purchased a simple and cheap 8x10 frame from walmart (my company caters to high end art clientele) and replaced the stock mat with mine. The special plexi was made by a local plastics fabricator (Tap plastics should be able to make one of these out easily). Its simply regular 1/8" plexi cut in two pieces and glued to an 8x10 panel.
Victor
__________________
Big Screen/Small Space! My 13x12 Bedroom HT
Think small, project big!
Small theaters gallery
victor-eyd is offline   Reply With Quote
Old 01-11-07, 04:14 PM   #3   |  Link
Josh Z
Cranky Member
Victor, what font and size is that?
__________________
Joshua Zyber
Old 01-11-07, 05:07 PM   #4   |  Link
victor-eyd
Quad Yeah!
I think its Broadway or similar and probably around a 20-25pt size. I just guesstimated something that was about 4-4.5" wide or so.
__________________
Old 01-14-07, 12:10 PM   #5   |  Link
Josh Z
Cranky Member
Well, I printed something off in Broadway font and it looks OK, but I'm still hoping for something a little more professional. If anyone has any suggestions, I'd appreciate it.
__________________
Joshua Zyber
Old 01-16-07, 03:43 AM   #6   |  Link
BFauska
You could look at Dafont.com and see if they have any great fonts for this. Then it would just be a matter of printing it out with good enough quality to look professional.
Later,
Brian
__________________
I love NEW technology, it makes the stuff I can afford even cheaper.
BFauska is offline   Reply With Quote
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.11870503 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
