AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > HDTV > HDTV Technical
Forum Jump
Old 01-11-07, 10:11 AM   #1   |  Link
mountain
What's the difference between these two?
I'm looking for some cheap component cables and stumble upon these but I don't know the difference the between them... Does it worth to spend extra cash over the other? Thanks in advance.
3Ft 3-RCA Component Video Cable (RG-59/u)
PREMIUM 1.5FT 3-RCA Component Video Coaxial RG-6 18AWG 75Ohm Cable
Edit: BTW, I'm using this for my DVD Player and VCR. Thanks
mountain is offline   Reply With Quote
Old 01-11-07, 10:22 AM   #2   |  Link
AntennaMan1
The cheaper ones are made of RG-59 and what appears to be cheap connectors. The "Premium" ones are made of RG-6(heavier gauge) coax and what appear to be more positive holding connectors. The cost differential between the two kinds of coax, for such a short run is effectively $0. The difference in cost of the 6 connectors, bought in bulk is probably around $2. The cheaper cables, because they're made of smaller gauge coax, would be more pliable.
AntennaMan1 is offline   Reply With Quote
Old 01-11-07, 10:35 AM   #3   |  Link
mountain
So you're saying it's not worth it? If so, what would you recommend? Thanks
Old 01-11-07, 11:02 AM   #4   |  Link
cavu
Luftmensch
cavu's Avatar
AVS CLUB MEMBER
Thumbs up
ANYTHING made by Monoprice !
They are one of the most respected suppliers on AVS! Very low prices and excellent product and service!!
__________________
“The greatest obstacle to discovery is not ignorance — it is the illusion of knowledge.” - Daniel Boorstin
“Our lives begin to end the day we become silent about things that matter.
- MLK
cavu is offline   Reply With Quote
Old 01-11-07, 03:23 PM   #5   |  Link
AntennaMan1
How did you infer this? You asked for the differences, I obliged.
Old 01-11-07, 08:44 PM   #6   |  Link
mountain
Yes and thank you but I also asked if it worth to spend $7 to get the other component cables. Please let me know. thanks
Old 01-12-07, 09:30 AM   #7   |  Link
videobruce
SelectaVisionSupport
Profit.
I bet no one could even measure the difference between the two, let along see it. As far as one being RG59 and the other RG6, I would doubt that unless one would cut the cable and look at the cross section. With every cable I have cit open (for one reason or another) 90%+ is insulation and very little conductor (copper etc.). Cheap audio cables are notorious for this. A thick jacket and nothing inside. Makes you wonder that they work at all.
__________________
Mergers, acquisitions, takeovers; we all lose. Stop taking the side of these mega corporations. All they care about is the top 10%.
That's what 28 years of de-regulation has done.
videobruce is offline   Reply With Quote
Old 01-12-07, 10:23 AM   #8   |  Link
moxie1617
For a 3 ft run I would save the $7 and go with the less expensive cables. The more expensive 18AWG cables are going to be stiff and, at least with my setup, would be a pain to run from one shelf to the other in my cable raceway. If I were running more than 6 ft of cable, I would choose the more expensive cable.
moxie1617 is offline   Reply With Quote
Old 01-12-07, 12:55 PM   #9   |  Link
mountain
Thanks guys, I really appreciated.
Old 01-12-07, 03:11 PM   #10   |  Link
AntennaMan1
Just working from the listed specs.
We've taken to making our own component cables. If it wasn't for having 10s of thousands of feet of RG-6 on hand, I'd go with RG-59 for these cables because of the stiffness of the RG-6.
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.42579508 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
