AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > HDTV > HDTV Technical
Forum Jump
Old 01-12-07, 11:07 AM   #1   |  Link
ekoli
New Member
New Member Who needs some Help!!
Hello Everyone,
I would greatly appreciate any helpful information you could provide in regards to something I am curious about.
I have a Sony LCD Rear projection TV with a DVI output. I also have a few sources, (set top box, and PS3 etc..) that I hook up using the DVI output. Lately, I have noticed that my HD picture is not as clear as it used to be. I am worried that I may have damaged the output on the TV. My question is, how would you know if it is damaged? It doesnt look damaged physically, and there is no "snow" on screen, it just doesnt look as clear as it used to be. Is there a definitive "symptom" that would occur if in fact my output was damaged, so I can effectively rule that out as a possible reason for lack of clarity in picture lately?
Please Help!!
Thank you
ekoli is offline   Reply With Quote
Old 01-12-07, 11:34 AM   #2   |  Link
mjones73
Just another member
You'd be better off posting display issues in the display forum.
http://www.avsforum.com/avs-vb/forumdisplay.php?f=63
Just to rule out the DVI input, I'd try hooking your components up via the component input to see if the PQ is the same or if it's just the DVI input having issues. Also check the calibration settings on the DVI input to see if something was inadvertently changed.
__________________
Matt
Please don't PM me with technical questions that should be posted in the forum.
mjones73 is online now   Reply With Quote
Old 01-12-07, 12:01 PM   #3   |  Link
ekoli
New Member
Sorry for the stupid question,
But how exactly do you check to see if the calibration settings were changed?
Also, I recently bought (and returned) a mechanical dvi switch because of "sparkles" on input 1. Would it be possible that the switch damaged the tv?
Thanks for your help by the way!!
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.10236692 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
