AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > HDTV > HDTV Technical
Forum Jump
Old 01-12-07, 04:27 PM   #1   |  Link
0db
HR10-250 - STUPID question
Is there any way I can force this thing to output HDMI and Component simultaneously? When I plug in an HDMI cable it kills the component outputs, and I'd REALLY like to feed my TV and my projector simultaneously for the superbowl.
Barring this, is there any cheap way to split the component output to 2 devices without massive signal loss?
0db is offline   Reply With Quote
Old 01-12-07, 05:38 PM   #2   |  Link
rlj5242
Yes. You have to remove the drive, boot to linux and change some software settings. Also, it only works with specific internal HDMI boards. Details are in the Tivo Community sub-forum, in the DirecTV HD Tivo section.
-Robert
rlj5242 is offline   Reply With Quote
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.08456206 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
