AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > HDTV > HDTV Technical
Forum Jump
Old 01-12-07, 05:24 PM   #1   |  Link
jeff8073x
New Member
Problem With HDMI Connection
I have a cable box from Comcast with HDMI output and I cannot get a picture working on my Sharp LC-26DA5U through its hdmi port. Am I forgetting to do something? I have the box set up to do 16:9 720p.
jeff8073x is offline   Reply With Quote
Old 01-12-07, 05:41 PM   #2   |  Link
Ratman
1) has the HDMI output been enabled by the cable provider?
2) does your TV "accept" 720p video input
3) try setting to 1080i
4) any error messages? what are the symptoms/results?
Ratman is offline   Reply With Quote
Old 01-12-07, 06:12 PM   #3   |  Link
jeff8073x
New Member
1) The HDMI Output has to be enabled?
2) Yes, it does.
3) I can try that
4) No sound and no picture.
Old 01-12-07, 06:26 PM   #4   |  Link
Ratman
1) providers have been known to not enable HDMI, firewire, USB, etc on STB's... had to ask.
4) unplug both the TV and STB from power (remove cord from wall). Power up TV, then STB. May just a an HDCP "handshake" issue.
Old 01-12-07, 08:26 PM   #5   |  Link
morficus
I just got my HD cable box from Charter (Scientific Atlantic 8300HD).
The manual states that one should not hook up your cable box with an HDMI cable unless the TV supports HDCP.
If the TV does not support HDCP, then the outcome is just what you are getting (not audio, no video)
So I would recommend checking that your TV supports HDCP
morficus is offline   Reply With Quote
Old 01-12-07, 08:43 PM   #6   |  Link
Ratman
99.9% of TV's with HDMI are HDCP compliant. Although... there have been some "compatbility" issues reported about some TV's and STB's.
Old 01-13-07, 12:34 AM   #7   |  Link
jeff8073x
New Member
I just checked sharps manual online for my tv and mentions nothing about hdcp. I then checked one of the46/52" models and it says hdcp. I guess maybe mine doesn't support hdcp.
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.15491009 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
