#1 | Link |
Gateway FPD2185W
Coaxial to RCA Cable, how to?
Hello all-
I'm a college student, and we've got a coaxial cable (F-type connector) running to a television in our dorm room. That works great, but I've recently purchased a projector, which does not have coaxial inputs. How can we convert a coaxial cable to RCA? Here's the background: We've purchased a TV demodulator from alltronics (search using Google, I can't post the link because < 5 posts) This came in the other day, and I tested it out at my friends house. It didn't work very well; an image came on the screen that was clearly a television image, but it was blurry and color-distorted. He has a satellite subscription service, and I think that is the problem. Our service in college is a subscription service, but there's no tuner box required (the coaxial comes from the wall and goes directly into the TV). I'm going back Sunday, and hope that this will work, but is there any reason it might not work? I know that descramblers are illegal, and I don't think that this demodulator functions as a descrambler. Can anyone think of any other ideas? The projector has VGA, RCA, and S-Video inputs. I think if things really come down to the wire (i.e. Super Bowl time!) and nothing works, I can break down and buy a USB TV Tuner...any recommendations? Thanks! |
#2 | Link |
You need a cable box. You connect coaxial cable between the wallplate and the box. Then you can connect a component video (red, green and blue) cable to a component-to-VGA adapter, or use a S-video, or the yellow RCA composite port. Make sure in your projector menu all sources are enabled and you set it to auto source.
#3 | Link | ||
The TV tuner is for tuning and demodulating OTA or CATV ...the sat receiver is for tuning and demodulating sat signals...they're different, and not compatable. Quote:
#6 | Link |
Señora Member
I found the spec sheet. Output is video 75 Ohm, 1 Vp-p. In other words, it's composite.
Easy fix: Get a coax cable and put an F-connector on 1 end so you can screw it into the demodulator output. Put an RCA plug on the other end. Center conductor to the pin, shielding to the shell, it should fit no problem. Plug it into the RCA input of your projector. I'll bet that the projector RCA input jack is colored yellow, an indication that this is a composite video input. |
#7 | Link | |||||
Gateway FPD2185W
OK, thanks for the responses:
Also, about hooking it up to the sat receiver: I initially hooked it up straight from the wall and we got that weird crappy signal (distorted but viewable). Then I took the sat box and took the coax output from it and decided to demodulate it. Images came up very sharp, but only for a few seconds, then they disappeared. Quote:
#8 | Link |
The co-ax from the cable company has TV channels #2 and up (it may also have the new digital channels, these maybe encoded and only available through the newest cable company Set Top Box "STB").
The VCR tunes to a channel and the RCA outputs are Video and Audio (of that one channel). |
#9 | Link | |
BTW, a TV tuner, without a demodulator, is useless. |
#10 | Link | ||
Gateway FPD2185W
#11 | Link | |
Technology inspired
How to hook up a VCR to the projector: Cable TV Coax from the wall outlet would go to the INPUT on the VCR. Locate the YELLOW, WHITE, and RED OUTPUT jacks on VCR and use RCA cables to hook up to projector. On the projector there should be an input select to choose the composite (yellow, white, red) jacks as the video display. You would change channels (or watch VHS movies) with the VCR's remote or front panel buttons. Not all VCR's are stereo, so you might only have a yellow and white wire. This will still work, but with one audio speaker instead of two. |
#12 | Link |
Just remember the component-to-VGA adapter will give you a better picture then the yellow RCA composite interconnection.
Also, audio through a projector is the minority (for home theater). The small speakers in projectors are used as a one time cue for presentation for hotels, etc. In big home theater all audio will be amplified from a prepro, AVR, separate power amps, etc. to the speakers. |
#14 | Link |
Some NTSC tuners today now have component outputs:
http://www.crutchfield.com/S-ccadXmv...p?i=305SIRT165 http://search.yahoo.com/search?p=Wha...p=mss&ei=UTF-8 With a front projector and one of these tuners you can get this component connection. |
| Bookmarks |
| Thread Tools | |
