AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > HDTV > HDTV Technical
Forum Jump
Old 01-13-07, 04:23 PM   #1   |  Link
cip4465
HR20 HDMI with Samsung DLPs?
Purchased a DirecTV HR20 HD DVR box at local Best Buy in anticipation of getting a Samsung 7178 DLP TV.
Anyone using a HR20 through HDMI to a Samsung DLP? Any issues in compatibility?
cip4465 is offline   Reply With Quote
Old 01-13-07, 05:05 PM   #2   |  Link
texasbrit
Lots of people are using them. Lots of people have compatibility problems. Most if not all Samsungs are using a specific HDMI/HDCP chip which is not compatible with some other HDMI implementations. Apparently neither of the implementations are "wrong", just different, and the HDMI/HDCP specs are not precise enough to guarantee compatibility. The HR20 works OK with just about every TV on the market that does not use this specific chipset. DirecTV has already released some modifications to the software to improve compatibility and more are on the way. If Samsung changed the chipset they would have to install a new electronics board in every TV; since most of the HR20 implementation is in software DirecTV should be able to make the devices compatible.
Meanwhile just use component video; the PQ will be the same. HDMI's only real advantage is thst it is a single-cable solution.
texasbrit is offline   Reply With Quote
Old 01-14-07, 11:46 AM   #3   |  Link
cip4465
Thats not good to hear! But, looks like there may be a chance anyway. On another thread, there is a user that has been using his HR20 through HDMI with the same Samsung DLP TV I am looking at! This is good news, hopefully I am lucky with my setup too. Maybe its the new software available for the HR20.
Old 01-15-07, 12:05 PM   #4   |  Link
cyeaman
New Member
My HLS5087 is working fine with a HR20 via HDMI. So, it's either luck or the upgrade.
cyeaman is offline   Reply With Quote
Old 01-17-07, 10:53 AM   #5   |  Link
rclAlaric
New Member
Any issues with the HR20 connecting via DVI with an HDMI/DVI converter?
I have an older Sammy DLP pre HDMI.
I am currently using an H20 with the Sammy and it is working fine.
rclAlaric is offline   Reply With Quote
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.09351301 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
