#1 | Link |
help with hdmi
Ok, here is my story. I have a Sharp LC32D40U. I just hooked my Comcast cable box up to my TV.
Now, my DVD doesn't work. I get audio (L/R) but no video. I tried new cables with no success. I tried the DVD using the red/white/yellow cables on another TV and it works. So I know it is the TV. I then tried to use these inputs for the cable box, and same problem. On thing to note. The component cables do work the DVD video. But I have cables through my walls so it is not that easy to just run component for the DVD. Does running HDMI screw up the old school RCA cables or something? |
#4 | Link |
AVS GOLD CLUB MEMBER
You may have incompatible HDMI problems. Sharp TVs have trouble with one DirecTV receiver too. If you try a yellow input, you might have to set the box to output 480i. Many source devices don't output HD and 480i simultaneously.
__________________
Pat While I may link to and mention products as examples, I don't recommend specific products. |
#5 | Link | |
Here is what I want to do. Have my cable box set to HDMI, and my prog scan DVD player to Input 1 or 2 (red/white/yellow). Is this possible?
Before I had my cable box set up with component cables and input 1 and 2 worked fine with the DVD player. This problem started when I went to HDMI for my cable box. Like I said, my DVD player works with the component cables, but I'd have to rerun everything thru my walls. |
| Bookmarks |
| Thread Tools | |
