AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > HDTV > HDTV Technical
Forum Jump
Old 01-13-07, 07:41 PM   #1   |  Link
keldarironfist
is there a way to boost QAM tuning performance? more channels,better lock ons etc...
i notice sometimes i can occasionaly get other channels occasionaly or barely,sometimes these are the pay channels etc... im using the samsung h260f tuner and im wondering if there is anything i can do to increase the general performance of the QAM tuning? maybe a signal booster? im just curious,thanks.
keldarironfist is offline   Reply With Quote
Old 01-14-07, 11:54 AM   #2   |  Link
biker19
The chs you are seeing are the neighbor's VOD feeds - be glad you get them at all. If you are getting break ups on the regular chs then an amp might help but the cable co should fix that.
biker19 is offline   Reply With Quote
Old 01-14-07, 01:34 PM   #3   |  Link
keldarironfist
i noticed that it is the neighbors bcuz occasionaly while watching one of the free on demand movies (all of this is non hd) the occasional naughty movie came on but then i started to notice pausing rewinding and fast forwarding. then i realised i was getting other peoples feeds,i will eventualy do OTA as well,i wonder if ill experience the same thing,ive heard you get alot moe channels through OTA then QAM.
Old 01-15-07, 09:21 AM   #4   |  Link
John Mason
Presumably a cable tech measuring the signal amplitudes on several bands would find them okay. If a frequency band was too low from the incoming line, that might influence QAM performance, and would require tweaking farther back on the path. Measuring at the STB input would also ensure any cables or splitters between the incoming line drop and the tuner were okay. Ensuring any splitters are adequate (5--1000 MHz?) and connections are tight are a few DIY steps--other than substituting other hardware known to be good. A line amp might degrade performance if signal levels are adequate to start with. -- John
John Mason is offline   Reply With Quote
Old 01-15-07, 12:28 PM   #5   |  Link
biker19
Originally Posted by keldarironfist
i,i wonder if ill experience the same thing,ive heard you get alot moe channels through OTA then QAM.
Unlikely, unless you are close to a lot of transmitters and the cable co has limited clear QAM chs. And of course you'll never get VOD OTA.
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.11764002 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
