#1 | Link |
inexpensive RF controlled lights
Anyone know of any economical (less than $500) RF controls for lighting.
I have 3 zones (2 recessed cans each) that need control. I would like to have preset lighting scenes but that isn't necessary. I just need to be able to turn on and off and gradually dim them. I can't use IR because my HT room doesn't have any wall plates in the room, they're in the hallways that lead into the room. The only thing I can think of using are the RF controls for ceiling fans. Each unit can power up to 400watts. They run $40 each. Plus you can change the frequency for each station with dip switches so they don't all respond at the same time. Are there any remotes out there that can "learn" RF signals to control this? Otherwise I can use one of the remotes that comes with the unit but I would have to take the battery cover off each time I want to change the lighting to be able to switch between zones with the dip settings. Doable, but a pain in the arse. |
#2 | Link | ||
#3 | Link |
Nobody Likes You
The Logitech Harmony 880 Remote (along with many other RF remotes) can control X10 lighting. I personally love X10 as a budget solution since the devices are readily available in bulk on eBay for very affordable prices since the technology has been around since the '70s.
#6 | Link |
x10 is a good, cheap way to go, but also take a look at smarthome.com. They carry some x10 stuff that's impossible to find on x10's website.
One thing you may also want to look for is an x10 IR to RF Receiver. This way any learning remote will allow you to control the x10 stuff without needing the 880/890. |
#7 | Link | |
Nobody Likes You
#8 | Link | |
Time to get on it! I already have x10 stuff!
__________________
Samsung S5687W 1080p DLP + PS3= Heaven! |
| Bookmarks |
| Thread Tools | |
