#1 | Link |
New Member
Okay, I'm very inexperienced at dealing with HD, so I'll try and be as clear as possible.
I live in an apartment building in Chicago. I just purchased the HD package with Dish Network. I have an 811 receiver. I have been told that our building can't handle MPEG-4, only MPEG-2, which is preventing me from getting the local HD channels that are broadcast through Dish (I have the local package as well to get local channels-SD). So, basically I'm under the impression that in order to receive any HD local channels, I need an antenna. I picked up an RCA ANT1250, it's an indoor antenna, and have it hooked up to my receiver. I went to AntennaWeb, and typed in my address and zip code (60610), and these were the results: Quote:
I really have no idea what I'm doing wrong, what I'm doing right, or what I'm not doing that I should be. Is it a problem that the 811 is an MPEG2 receiver? Am I screwed because I live downtown around a bunch of big buildings? I would appreciate any help anyone can offer. |
#2 | Link |
RETIRED
You may want to check the Chicago Local section ,I think there might be some that live in the Concrete Jungle,that might be of some Help?
http://www.avsforum.com/avs-vb/showthread.php?t=444398
__________________
"No matter where you go...there you are." |
#3 | Link |
You are 0.8 miles from most all of the TV and FM transmitters in Chicago, and you have a "45 dB gain, Amplified Antenna".
That's a recipe for overload disaster! Try some very simple rabbit ears, or a plain-old loop antenna (like they used to give away with new TV sets). Or, just stick a small piece of wire in the "F"-connector and see what you get. You might wind up just needing to tape a small loop of wire to your window glass as a permanent solution.
__________________
Ken English, Sr. Engineer, KSL-TV/-DT. "Not a REAL Engineer, but I play one in TV" |
#4 | Link |
New Member
Thanks for the advice Ken. I tried the antenna without the amplification, and I've also tried just using a piece of wire, but I still can't get my receiver to pick up anything. If I do an analog scan my receiver picks up all the channels that are broadcast by default through all the apartments in the building, but I do a digital scan and it finds nothing. I have to be doing something wrong here, but I can't figure out what.
| Bookmarks |
| Thread Tools | |
