AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > HDTV > HDTV Technical
Forum Jump
Old 01-14-07, 03:33 AM   #1   |  Link
toxicpenguin
Toxicpenguin
What's the best solution - HDMI DVI connections
I would like some help in the best solution for the components I have:
Samsung 50 inch DLP - 1 HDMI input
I would like to connect:
PS3 - HDMI to HDMI (audio and video in single cable)
Oppo DVD - DVI to HDMI (video thro DVI, audio thro Optical)
STB - DVI to HDMI (video thro DVI, audio thro Optical)
PC - DVI to HDMI (video thro DVI, audio thro Optical or no audio)
I looked around online, and have come up with 2 options: either get the Sony STR-DG800 which has 2 HDMI passthro connections OR get a 5x1 HDMI Switch
The PS3 is audio and video out to the tv, so that poses no problem.
The other 3 devices is a problem, as they are all DVI (video out), and will compete for the solitary audio IN connection in the TV.
The Switch would work perfectly for any 2 connections, but i have no idea how i could transfer audio to the tv without manually having to swap audio cables
The Receiver would again pose no problems for 2 connections, however i would have to route an extra optical out from the tv back to the receiver as it is a HDMI passthro
What are my other options?? Any suggestions, products out there i might have missed???? I want to try to avoid using component cables as far as possible.
Thanks!!
toxicpenguin is offline   Reply With Quote
Old 01-14-07, 09:56 AM   #2   |  Link
mjones73
Just another member
Something like this would do the trick for you - http://www.engadget.com/2006/06/10/o...-with-toslink/
Haven't used one personally but it does HDMI and optical switching.
__________________
Matt
Please don't PM me with technical questions that should be posted in the forum.
mjones73 is offline   Reply With Quote
Old 01-15-07, 07:57 PM   #3   |  Link
toxicpenguin
Toxicpenguin
That is a pretty good solution! - The problem is that when i looked at the back of my TV, there is optical out, but no optical in!! SO --- i will have to use the RCA cables to route sound from the DVD and the STB.
So i guess my choices are:
This box : 300 bucks
Regular switch (5x to 1 HDMI) : 100 bucks
Sony Receiver (7.1 with 2 HDMI passthro) : 300 dollars (in this option the STB can route thro component cables
With the receiver, i can get component upconversion of my Tivo and VCR (S video Connections) which i cannot get with the other choices, plus FM, XM and 7.1 surround
I guess if i choose the SONY, my PC will have to be "manually switched" as needed!!
Anyone has had any bad experiences with the STR-DG800?? Or is it a good buy?
Old 01-16-07, 08:54 AM   #4   |  Link
mjones73
Just another member
"With the receiver, i can get component upconversion of my Tivo and VCR (S video Connections) which i cannot get with the other choices"
Your TV upscaled these sources to it's native resolution for display already, you may or may not get better results using the scaler in the AV receiver instead.
"Anyone has had any bad experiences with the STR-DG800?? Or is it a good buy?"
Check the Audio forum lower down on the list for info on AV receivers.
__________________
Matt
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.11127591 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
