#1 | Link |
New Member
I recently switched to Dish Network because their sales folks called up and told me they offered network channels in HD. I should have done more homework I guess.
When I switched I lost: Local Channels in HD Our local HD sports channel that shows the Denver Nuggets and Avalanche Hundreds of On-Demand movies HBO on Demand Worst of all is that the supposed 25 HD channels that are part of Dish's "VOOM Network" all look horrible and not like the 1080i I had on cable. Discovery HD in particular looks fuzzy and has artifacting when compared to what the same programming looked like under cable. Does anyone know when: 1. Dish Network will actually have real On-Demand 2. Does Dish mess with the actual resolution to free up bandwith? 3. Why would cable 1080i look better than Dish 1080i all other variables the same?? I WOULD TRADE ALL THE WORTHLESS CONTENT ON THE VOOM NETWORKS (THE KUNGFU CHANNEL, ect) TO HAVE ABC, NBC, AND FOX IN HD AM I ALONE HERE? ANY THOUGHTS TO MAKE ME FEEL BETTER ABOUT MY 18month COMMITMENT? Last edited by DavidL20; 01-14-07 at 03:08 PM.. Reason: Title more bold |
#2 | Link | |||
David,
Can't you cancel in the first 30 days? That said, how far do you live from your local broadcasters? AFAIK, all of Dish Network's modern receivers will integrate DTV/HDTV locals from an off-air antenna into the guide with the satellite channels. If you live close to the broadcast affiliates, a simple set-top antenna would add all your DTV/HDTV local networks to your program guide at the appropriate channel numbers. If you live 30-50 miles away from the broadcasters, see the Local Info and Reception forum to see what others in your area recommend. Quote:
#3 | Link |
Just another member
Cancel if you still can, you won't be happy if you keep Dish and as pointed out, you will need to add an additional antenna to get your local channels back via OTA though you won't get the sports network back.
__________________
Matt Please don't PM me with technical questions that should be posted in the forum. |
#4 | Link |
New Member
I would like to cancel but my wife is tired of people in her house
![]() I am too far away from the radio tower to pick the HD channels up via local broadcast. Does Dish downgrade ALL of their HD content, or just some of it? If they are downgrading their 1080i that means we are probably light years away from the satalite providers giving us 1080p no? |
#5 | Link | |
#7 | Link |
New Member
If I could at least find out that Dish was working on the problem I would consider not canceling, but I cant even get their technical support people to answer my questions about what they are trying to do to remedy the bandwith problems.
Anyone have any good articles to read about Direct TV and Dish Networks solutions? |
#8 | Link | ||
#9 | Link | |
#11 | Link | |
Just another member
__________________
#12 | Link | ||
AVS HDTV Moderator
AVS GOLD CLUB MEMBER
__________________
'Better Living Through Modern, Expensive, Electronic Devices' ™ |
#13 | Link | |
Furthermore, there is plenty of capacity on 148W where they could put full bitrate versions of HDNET and HDNET Movies just as they have done with HBO-HD and SHO-HD for those that were interested. As they already have these options available, to this day I fail to see why they are not used - and do not consider it a good omen. |
#14 | Link |
Just another member
Thanks for clearing that up, wasn't sure what exactly their capacity was.
Regardless the OP is not going to get his local's in HD or his RSN back in HD anytime soon, moving to Dish was a bad mistake for his situation regardless of the national HD channels Dish does or does not have.
__________________
#15 | Link | |
We recently upgraded to the 211 (have 2 of them on different sets) with Dish and all of our channels look great. HD content is outstanding and SD is good. We only have the their "top 180" (whatever those are), but the additional stations with the voom pkg. are a nice addition to the few we had.
I 've only just joined on here and when I came across this, I was a little surprised. Is it just where you are physically located? I thought that's what satellite was for. To get good pictures when you're too far from the broadcast locations (which we are; without getting an enormous antenna). I hope you get this worked out. Nothing's worse than bad TV. |
#16 | Link |
I recently siwtched to Dish from cable (Cox). I can tell you one thing for sure...the picture is 100x better! More HD options and the picture on the non-HD stations are pretty good too. I hooked up a little indoor antenna to get locals and they look outstanding. The only thing I miss is that the guide does not populate with programing information on the locals...it just states "Digital Service" all day for the once I receive over the antenna. Maybe you got a crappy installer?
#18 | Link | |
#19 | Link |
New Member
Switched Back
Thanks for all the replies.
I switched back, and Bresnan (subsidiary of Comcast) gladley took me back waving any hook up fees. Discovery HD and HD -Net look 100% better! I have Altitude Sports HD, all the On-Demand content and ALL my local channels in HD. Anyone thinking of getting Dish -read the fine print. On-Demand is basically non-existant and HD channels look horrible. Now, to be fair: If you have a 720p plasma you probably are not going to care as much...but for those of us who have 1080p lcd or 1080p plasmas -a degraded HD picture is horendous looking and annoying. Conusmers must create a market for QUALITY HD picture to keep the bandwidth technology moving along. Dish Network has a long way to go. Forget about the whole 1080p senario: They arent even outputing quality 1080i Thanks for all the advice and I am glad I canceled before the 30 days. p.s Dish had great customer service and great people -just inadequate technology |
#20 | Link |
[quote=DavidL20]Thanks for all the replies.
I switched back, and Bresnan (subsidiary of Comcast) gladley took me back waving any hook up fees. Discovery HD and HD -Net look 100% better! I have Altitude Sports HD, all the On-Demand content and ALL my local channels in HD. Anyone thinking of getting Dish -read the fine print. On-Demand is basically non-existant and HD channels look horrible. Now, to be fair: If you have a 720p plasma you probably are not going to care as much...but for those of us who have 1080p lcd or 1080p plasmas -a degraded HD picture is horendous looking and annoying. Conusmers must create a market for QUALITY HD picture to keep the bandwidth technology moving along. Dish Network has a long way to go. Forget about the whole 1080p senario: They arent even outputing quality 1080i Thanks for all the advice and I am glad I canceled before the 30 days. p.s Dish had great customer service and great people -just inadequate technology[/QUOTE] [color=Lime] Great customer service ? Wow you Really got lucky! You should think about playing the lottery soon. [/COLOR] ![]() |
#21 | Link | |
I am confused about the bad picture in HD that some have complained about and as to why. If I'm getting excellent PQ with Dish in my area, it would seem that there must be some hardware problem for those that don't? My little Sanyo 27"crt HD even gets a pretty darn good picture. And with all the many times I've called Dish over the years for one thing or another (99% of the time someone messed up the remote) I've never had anything but great service. I think it's the same with any kind of problem, we usually only hear about the ones that are having the problem. Those that are happy usually are quiet. Except me ![]() |
#22 | Link |
New Member
Wouldnt Show
Lisa
The bad picture quality I am talking about doesnt show up unless you have a large screen 1080p display. The downsample the 1080i picture resolution to allow for more HD channels within their allowed bandwidth. So on a 720p plasma you probably are not going to notice or care.....but on a 50inch 1080p LCD it really shows when they tinker with the bitrate. Its a bit like when a kid adds water to replace the whiskey they stole out of dads liquor cabinet. It wouldnt matter much with cheap run-of-the-mill whiskey, but dad would probably notice if his expensive bourbon was watered down. DAvid |
| Bookmarks |
| Thread Tools | |
