#1 | Link |
Cheap OTA STB and boosted indoor antenna
I have searched to no avail. I would appreciate ANY INFO ON A CHEAP WAY to
get local OTA HD on a HD ready tv without an internal tuner. What type of cheap STB would YOU RECOMMEND ? I DID FIND SOMETHING ABOUT A POWERED INDOOR ANTENNA ? I don't want to spend alot and don't want to run wires for the antenna in case I do spend the dough on a DISH HD reciver in the future which according to them will pass the HD locals without an OTA antenna, of course for the 5.95 a month or whatever. Just want a taste of HD for football games. Thx for any info. Bill E. |
#2 | Link |
Hughes HTL-HD for OTA HD Box. It's a former DirecTV box but will work as standalone without requiring Access Card and without requiring subscription. Try the Zenith Silver Sensor ZHDTV1 Antenna without a signal booster and see how that works out.
If you are trying to pick up a signal that is 80+ miles away, then try a (pre)amplifier. I personally am using the Motorola Signal Booster, with 15dB amplification and 2dB of noise. Note that using a signal booster might strengthen the signals you get across the board but it may actually screw up the signals too if the broadcasting station is too close. I've got a CBS station that is about 9 miles away and I get breakup sometimes with the amplifier (without it, I don't get the stutter and macroblocking). It does, however, boost my signals that are originating from 80+ miles away, which coincidently include another CBS station that produces very few video stutter. |
#3 | Link |
Caffeine Free
Do you have to connect the coax "out to tv" along with the dvi connection from the hughes htl-hd to the tv concurrently? I am considering this for myself and noticed on pg. 31 of the user manual that this is pictured. I don't have a coax in on my tv.
Thanks Last edited by ataxic_dentist; 01-14-07 at 09:51 PM.. |
| Bookmarks |
| Thread Tools | |
