AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > HDTV > HDTV Technical
Forum Jump
Old 01-15-07, 12:30 AM   #1   |  Link
bacid
New Member
3250HD Problem
my inlaws bought a new panasonic plasma (PX600U) along with a samsung HTIB (i know, this sucks, but they are newbs). with this they also received a 1yr free HDTV w/ 3250HD STB.
the problem i'm having is that when i connect the 3250HD to the samsung HTIB using a dvi->HDMI cable the video flashes for a second and says this tv doesn't support HDCP and then the video goes completely off.
if i connect the 3250HD directly to the TV using the same cable it works fine.
if i connect another HDMI device to the samsung HTIB this also works fine.
so it seems the problem is ONLY when i connect the 3250HD STB -> samsung HTIB
now i've read the threads that state going to component is the easiest fix but unfortunately this isn't possible as the HTIB receiver is pretty barebones and only has *2* inputs, one being the old RGB and one being HDMI.
is there ANY WAY to fix this problem WITHOUT buying new equipment or are they screwed?
bacid is offline   Reply With Quote
Old 01-23-07, 01:51 PM   #2   |  Link
wpm1960
New Member
Run component (RGB) or DVI-->HDMI straight to the TV. Still run audio through the Samsung first using coax or optical.
wpm1960 is offline   Reply With Quote
Old 01-23-07, 07:07 PM   #3   |  Link
bacid
New Member
ya i ended up doing that in the meantime... the cable provider up here (rogers) has a fix for the 3250HD being released this week which should resolve the HDCP issue.
thanks for replying
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.09071803 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
