#1 | Link |
Distributing Cable signal 1 input to 12 outputs: Need help
Hi,
I need help in distributing cable signal to 12 outputs (3 in 3rd floor, 5 in 2nd floor and 4 in 1st floor). How should I go about it? I was thinking of the following: Input will be boosted through a signal amplifier (1 input to 1 output). This will be connected to a splitter 1 input to 3 output. Each of the outputs will be connected to each floor of the house. For the 3rd floor I will connect it to a splitter 1 input to 3 output, 2nd floor 1 input to 6 output splitter and 1st floor will be connected to a 1 input to 4 output splitter. Is this OK. Will I experience significant loss in quality? I was told I would have to use a tapoff. What is a tapoff? Please help.
__________________
Thanks Srikanth Koka Last edited by skoka123; 01-15-07 at 11:10 AM.. |
#2 | Link | |
First I would take the main cable and feed it into a 4 port tap then take the output of the tap and cable it to a 5 or 6 way tap on the 2nd floor, then cable the output of the 2nd tap to a 3 or 4 way splitter on the third floor. You may or may not need an amplifier try it with out and if your signal is weak add an amp. Remember all the signals are in a series config and if you have any unused ports on any of the taps or splitter terminate them. Let us know how you make out. Another option is to use a distribution amplifier on the first floor and run of the outputs to a tap on the second floor and then run the output of the tap on the second floor to a splitter on the third floor. |
#4 | Link | |
If we use a figure of 10dB feeding your house, purchase a signal amp to boost an additional 15dB (for a total of 25dB). Your 3 output splitter will feed each floor. Use an unbalanced 3-way. Use the -7dB leg to the 3rd floor. Then use a balanced 3-way. Each tv receives about 12.5 dB not including cable length loss. Use the -3.5 leg to the 2nd floor. A 6-way will have roughly -10dB each leg thus each tv receives about 11.5 dB (again, not including cable length loss). Use the other -7dB leg to the 1st floor. A 4-way will net each tv 11dB not including line loss. IMO, keep the dB value of each tv in the positive 1 to 10dB range. Your plan should achieve this. |
#5 | Link | |
__________________
Thanks Srikanth Koka |
#6 | Link |
Thanks for the replies so far.
I have gone through some of the other threads too. I contacted cabletvamps.com and they say I would need a different RF split for India (PAL system) and they do not sell them. (How I wish there was just one video system in the world!) Any idea what kind of splitters, amps and tapoffs I would need and possibly where they are avialable.
__________________
#7 | Link |
Tap versus splitter.
A tap is like a splitter with the difference being it (a tap) has it's taps (some value lower than the total power) and an output which is typically a few db less then the input. Keep in mind each Tap (leg) will have a higher loss value when compared to a splitter. The advantage of this allows you to cascade more taps in series so the power presented to the next tap is only a few db lower than the previous tap. I hope this is clearer then mud!! I will try and point you to a reference which should explain it better. |
#8 | Link |
Señora Member
The engineering term is "directional coupler". You "tap" off a portion of the signal from it for your TV and pass the rest down the line.
A splitter is a form of directional coupler that has equal value "taps" at the output side. In other words, 2 outputs (each 1/2 power or 3 dB loss), 3 outputs (each 1/3 power or 4.77 dB loss), 4 outputs (each 1/4 power or 6 dB loss). A directional coupler could have a single 20 dB tap (1/100 of the power). This is commonly used as the drop into your house from the cable system up on the pole. Does this mean that the next guy in line gets 99% (what remains)? Absolutely. That's why you have to balance how many customers vs. how many amplifiers to deploy out on the street. It's also why there are problems when you have new customers added to old systems. Each new user drops everyone else down a bit. It's not a problem until the design limit is exceeded. Some info is missing here. Taps (directional couplers), etc. have no dependency on the type of signal passed through it. The frequency range of the "India" system is what's needed, not that it's PAL. Last edited by GeekGirl; 01-15-07 at 10:48 PM.. |
#9 | Link |
Thanks a lot to both GeekGirl and RCbridge. Though it is still not crystal clear I am getting there.
What the splitter does is pretty clear. 10 outputs then each will have a signal strength of 10% of the input. In case of a TapOff of10 outputs then the output where the signal is tapped off gets 10%. What is unclear to me is what happens to the remaining 90% if they are not connected. In other words I have a Tap with 1 input and 10 outputs, only two of them are connected then will each of them have 50% signal strength? Is this what RCbridge was referring to as Series? (I guess the splitter is parallel then!!!)
__________________
#10 | Link | |
One more shot:
Since you understand how a splitter works, the tap is designed to pass some of the power to the next device in line (series) so in doing this each tap will have a loss larger then a typical splitter. Ex 4 way splitter (power divider) each leg has about a 7db loss, If power in = 0dbmv then each leg will have about -7dbmv. A 4 way tap can be designed to take the same 0dbmv in and provide each tap with a greater loss then the 7db of a splitter and pass on the extra energy to the next device in line (series). Ex if I have a tap value of 10db (compared to the splitter which was 7db) I have that additional 3db of power to pass on to the next device (in series with the tap) this is what comes out of the tap. You can design the tap to have more loss per leg and pass on more power. If you have a 10 way tap each tap will only get some percentage of the total power this is a fixed value so if you don't use all of the taps that value won't change, but you must load the unused taps with terminations. |
#11 | Link | |
For "antenna" or broadcasting band (VHF/UHF), they use a different connector, which has a larger, captive pin....or a socket. There are actually male and female connectors, which keep you from plugging, say, a VCR in backwards, with the antenna connected to the modulated output and the RF input connected to the TV's tuner.
__________________
Ken English, Sr. Engineer, KSL-TV/-DT. "Not a REAL Engineer, but I play one in TV" |
#12 | Link |
Think of taps and splitters using "the water analogy", something we used a lot in school.
Most people seem to think a splitter is like a "Y" with the same size of pipe coming out both "spigots" as what went in. In reality, the "pipes" coming out (of a two-way splitter) are each 1/2 the area of the one going in.....so it gives about 50% of the incoming "flow" to each output, minus a bit for "turbulence" or heat losses ("friction" or "turbulence" in our water analogy). A tap is much like the water distribution in your neighborhood. The big "pipe" (like a water main) has a much smaller "tap" coming off it (and often, you have some kind of regulator on your water line). Lots of water flows through the main, and a specific amount is tapped off for your house, with the rest of the main feeding similar setups at other homes. An RF tap siphons off a specific amount for it's own distribution, letting the rest pass down line. Some taps siphon off just enough to drive one set, others siphon off enough for several sets, using a built-in splitter to further divide the signals. Either way, you can't put ALL the water through the small pipes, and you can't put all the RF thru each of the splitter or tap outputs. You have to design the system for proper levels at the final outputs (that feed the TV sets), by computing the total losses of all the taps, splitters, and cable losses....usually the highest frequencies are what you use in computations. Using "dB's" (decibels) is the shorthand that we use. 3 dB is about 50% of the power. A 2-way splitter (all splitters are just cascaded 2-way splitters internally) looses about 3 dB plus a bit of friction/heat loss to each output, so, about 3.5 dB. A 4 way looses 3 dB+3 dB+ heat loss, or about 7 dB. And so on. So, say you want a +6 dBmV level at each set, you'd need to make +9.5 dBmV at the input of your 2-way splitter, or +13 at the input of your 4-way, or +17 at the input of an 8-way. The trick is to keep things balanced, too. So, always divide things equally, or use various taps (they come in different "tap off" levels) to keep levels balanced along a feeder line. You'll need an appropriately "sized" amplifier to make up the difference between the incoming signal and the signal at the end of all those taps and splitters, which you computed by adding all the losses.
__________________
#13 | Link |
OK. I think you have all successfully managed make me understand the difference b/w a splitter and a tap. Thanks...
Now I do believe the TV technician who said that the Taps have to designed along with the usage of the amplifier and the splitter was not bluffing. OK, if using a Tap is so complicated why one choose a Tap over a splitter. Specifically in my situation isn't an amplifier and three splitters enough, taking the formula dB = 10 * log(n) where n is the number of outputs of the splitter into consideration? Two more questions: 1) Does it really matter whether I use a PAL signal or NTSC so long as it is 75 ohms? 2) Does the logic of amplifiers and splitters work the same with a Satellite Dish such that I just need one Dish and as many settop boxes as the TVs?
__________________
#14 | Link | |
The difference in power level at the first split compared to the last split will be much greater when using a splitter over a tap. Do the math. You stated a 3 way split then a 6way split and last a 4 way split. Start with 0dbm and work your way through your scenerio (regardless of the starting power level) the difference of the input to the last stage will remain constant. Using taps (take a tap with a 2 db insertion loss) and work out the numbers. |
#15 | Link | |
#16 | Link | |
On further thought, it seems like it will be worth the effort to have a technician do it for me and this theoretical background has given enough knowledge to bug them. The major advantage I see with an Amplifier + Tap combination is that I can have a really fat pipe (read will lots of signal boosting) and then have a Tap just wide enough to let much signal as is required per TV. I truly appreciate your patience.
__________________
#17 | Link | |
4.8dB = 10*log(3) ... That is, for a one input two output splitter I need to feed +3dB to get 0dB out. For a 3 output splitter I need to feed +4.8dB to get 0dB out. This is what I understood from one of the posts by GeekGirl on another thread on this forum (http://www.avsforum.com/avs-vb/showt...&&#post8397060) and it seemed to match with specs at http://www.electroline.com/en/produc...fications.html. I am assuming that I can use this as a general thumb rule.
__________________
#18 | Link | |
As stated, the electroline site is using the wrong equation. They state +3dB= 2x reference level. This is a power ratio not a voltage ratio and is frequently confused. For example, if you increased your receiver from 500 watts from 250 watts, this is a 3dB increase (+3dB doubles your power. Power equation: dB=10 log power1/power2). If you asked for an amplifier that is 32x reference level, you would receive one with +30dB (when you actually needed a +15dB amp) and would seriously over amplify your set up. (Voltage equation: dB=20 log mV1/mV2) Last edited by Kolchak; 01-16-07 at 07:43 PM.. |
#19 | Link |
Señora Member
One more important piece of info into this fray. The satellite dishes need DC to feed the LNB. Using an RF splitter that does not have a DC pass-through will fail. There are splitters designed for satellites (rated for DC - xxx MHz).
The whole "dB" thing is a mathematical convenience so we can add and subtract instead of more complicated multiplcation and division. From this log identity: log(x * y) = log(x) + log(y). The "dB" is a ratio, named after Alexander Graham Bell. A "Bell" unit is very large, so we use 1/10th of that or a deci-Bell. That's why the "10" * log(). Hit google for historical references. Since a dB is a unitless ratio, the 3rd letter refers to an absolute reference. For example, a 0 dbmV is the ratio referenced to 1 mV into 75 Ohms which is a measure of power, (1 mV^2)/75 = 13.3 nW. These are agreed upon industry standards. We use 10*log() for power. Since voltage is V^2, that's the same as 2*10*log() = 20*log() as mentioned in Kolchak's equations. More than enough math, but it's the right background for the problem at hand. kenglish - nice water analogy. The terminations are used to keep the backwash turbulence from entering the main system flow. They soak up the reflections caused by an open port. Without them, the other signals get a bit perturbed... Last edited by GeekGirl; 01-16-07 at 10:59 PM.. |
#20 | Link |
In India currently we have three Satellite TV providers (commonly known in India as DTH operators). A fourth provider had to postpone their plan as the satellite had failed. Digital Cable (not the HD type) has also started rolling out recently.
To add to this confusion there are three more companies that are planning to roll out IPTV nationwide they are currenlty in the testing phase. I have two main cables running through the house. I plan to connect one to cable and one to satellite dish. So I do understand that I would be needing different type of RF splitter for Satellite dish. Can the RF splitter that is used for Satellite Dish be used for cable also?
__________________
#21 | Link | |
#22 | Link | |
I am sure once you know the specs needed that you can purchase the items somewhere!! |
#23 | Link |
You should do a search on SMATV equipment, FTA satellite, and satellite multiswitches....these will give you a lot of good info.
Satellite really has to have a single (or, two...in the case of dual tuner boxes) cable from each receiver, back to a common point...usually the multi-output LNBF, or a multiswitch. This is because there has to be a common "switching point" where the signals from all the different satellites and their polarizations come from. In the simplest case, the satellite "re-uses" it's (usually) 500 MHz downlink spectrum twice, coming down once in vertical or right-hand circular (RHCP) polarization, then again in horizontal or left-hand circular (LHCP). So, there, already, is a need to switch between two sources. So, with one satellite, the receiver has to send two different voltages: 13 VDC will power the LNBF and allow one polarization to pass down the cable, 18 VDC will switch the other polarization in to the line. Some systems use a "stacked" frequency scheme, which puts a second polarization in a 500-MHz wide band above the normal 950-1450 single band, but they aren't as common. When adding a second satellite, the receiver has to add a 22 KHz tone to the line, to get sat #2. To get a third or fourth satellite, another form of signalling is used, which pulses the 22 KHz. All of these still use the two DC voltages to control polarization. So, basically, on most systems, you must have a direct line from some common point to each receiver. You can incorporate this in to a "home run" MATV system, using diplexers. This then creates a SMATV or, "Satellite/Master Antenna TV" System. There is a very new technology, which requires special LNBFs, switches, and new receivers. This "assigns" a "private" bit of spectrum to each receiver, then converts the individual outputs of the LNBF or multiswitch to those "private channels", and feeds the entire thing down one common cable ("trunk") line. I'm not sure, without going back and researching it, if this line can also carry OTA TV, or if it uses portions of that spectrum. There are companies, like Fagor, Johannson, Kathrein, and Triax, that build these types of products. You might also want to check out "Tele Satellite International" Magazine. They have reviews and tutorials on this type of stuff.
__________________
#24 | Link | |
I just need to get some background information before entrusting the job to a professional. Unlike in US it is difficult here in India to find good, qualified technicians. I am currently getting my dream house constructed and I am trying to get many things done and this is one among them. I am not a hardcore D-I-Yer, but I would like to know what's happening when I entrust a job. Thanks to you all, I think, I have enough information to be prepared to face all the techno mumbo-jumbo that I am sure the technician is going to throw at me.
__________________
#26 | Link | |
Señora Member
You are only discussing the RF source distribution. What about the rest? You need to think about your room dimensions, audio / video equipment, media server, sound treatments, cabling, speaker placement, seating arrangements, lighting, etc. Everything plays together to give you a great experience. Good video requires a matching audio environment. If you are hiring a technician, perhaps instead you should budget for a qualified home theater installer and let him do everything. You may be too busy with house construction and not be able to spend the time needed to get your home theater the way it needs to be. This is the best time to get it right. If this is what you want to do, fine. If not, I wanted to be sure that you have considered the entire picture. There is an AVS forum for each topic (this thread is for your video). Some examples: The size of your display dictates seating arrangements, the walls of the room need to minimize sound reflection. Last edited by GeekGirl; 01-17-07 at 08:40 PM.. |
#27 | Link | |
I am planning to install a 120" screen for my projector. The room size is 25 feet long by 12 feet wide. I have already provided for internal speaker cabling for a max of 8.1 setup. I am yet to connect the speakers. I am planning on buying a Marantz receiver (SR7001 or SR8001) with Audessey calibration. Hopefully this will setup the audio well. I am not exactly flush with money right now and hence do not want to take professional help as of now. Most of the so called professionals here are more of enthusiasts and insist of turnkey projects which involves buying everything from them. Some even insist on HT construction. I will manage with Audessey and Avia for a while. I will take a professional's help later to get the acoustics right. All the furniture I have planned for the HT room are movable and hence shouldn't pose much of a problem. The major problem I face here in India is to find a certified HT Professional. I have not come across someone who is say ISF certified so far. I am sure there are a few available in India but it will be a super expensive affair.
__________________
#29 | Link | ||
I thought I understood how dB worked using the water analogy, where the -3.5 out on a splitter loses a little more than half of the signal strength. Now I am completely confused after the voltage equation. If 3.5dB is 1.5mV and 0dB is 1mV, then a splitter subtracting -3.5dB only decreases the strength by less than half (from 1.5mV to 1mV). Could either of you unconfuse my dead brain? Many Thanks |
#30 | Link | |
I agree, more than enough math! |
| Bookmarks |
| Thread Tools | |
