AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > HDTV > HDTV Technical
Forum Jump
Old 01-15-07, 10:43 AM   #1   |  Link
kruuth
HD-lcd. Need a Tuner/reciever for cable. Advice?
I just snagged a nice sony 1080 lcd 50 incher for a song, the problem is that it has no internal hdtv tuner. Right now I'm using my vcr to watch things and it looks just awful. I've got knology right now, and I know that they have some hdtv channels. Is there a way to get an external tuner so that I can watch tv and hdtv without using my vcr? I think anything would be an improvement from the quality from that.
Oh, I have knology, and I can't really get a straight answer out of them as to how many hd channels they have. The wife and I primarily watch CSI, so if that's in HD thet'd be the deal maker.
I've seen some receivers on ebay cheap. Are those worthwhile?
kruuth is offline   Reply With Quote
Old 01-15-07, 10:53 AM   #2   |  Link
mjones73
Just another member
First option would be to rent a box from Knology if they offer HD service. If Knology offers any unencrypted HD local channels then a QAM tuner could be used to receive them. I suggest you start off in the Local Reception forum here and see if you can find a thread for your area to see what other Knology users are doing for HD around you.
__________________
Matt
Please don't PM me with technical questions that should be posted in the forum.
mjones73 is offline   Reply With Quote
Old 01-15-07, 11:29 AM   #3   |  Link
kruuth
I tried local reception and most of it is back-fourth about channels but not much about knology. Is there not some sort of universal tuner box out there?
Old 01-15-07, 11:54 AM   #4   |  Link
mjones73
Just another member
No, there isn't a universal tuner box out there for cable. You need to start off with finding out what your cable company offers then go from there. If you'd like premium HD channels you are pretty much limited to renting a box from them or buying something like the Tivo S3 which will work with a cable card as long as they rent those. If you are just interested in local HD channels and they offer them via unencrypted QAM, you can use a QAM tuner to get just those, if not you are back to option one, renting a box. Your other option if you just want locals it to attempt to receive them over the air and skip the cable company all together. You'd need an ATSC tuner and the proper antenna for your area.
__________________
Matt
Old 01-15-07, 12:23 PM   #5   |  Link
biker19
Sammy 260 STB.
biker19 is offline   Reply With Quote
Old 01-15-07, 02:05 PM   #6   |  Link
kruuth
Samsung 260STB? What will that do for me?
Old 01-15-07, 03:01 PM   #7   |  Link
jtbell
Absent-minded prof
It can receive both unencrypted digital cable channels (QAM) and over-the-air broadcast channels (ATSC) from an antenna. It's a new model and is generally better than previous digital TV receivers. There's a long thread about it in this forum. Look for "DTB-H260F" in the title.
jtbell is online now   Reply With Quote
Old 01-15-07, 04:31 PM   #8   |  Link
kruuth
I see. Does anyone have a listing of the unencrypted channels for knology in the Tampa Bay area?
Old 01-15-07, 05:07 PM   #9   |  Link
kruuth
Oh, hows the samsung LST-3100A?
Old 01-16-07, 10:28 AM   #10   |  Link
biker19
Ask that in the proper thread:http://www.avsforum.com/avs-vb/showthread.php?t=420401
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.14994097 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
