#2 | Link |
OFFICAL HOME OF HDTV
Just use an HDMI to DVI converter plug or all-in-one cable. They don't cost much and will give you the exact same picture as HDMI does. You just won't have the audio on the same cable.
__________________
"PLEASE HELP STOP HDTV ABUSE! FEED YOUR HDTV AN HD SIGNAL!" |
#4 | Link |
No, there are not any, if you live in a Cox market that uses SA (Scientific Atlanta) boxes. Only the SA8000HD and SA8300HD converters have HDMI output. The SA3250HD has a DVI out, like someone else mentioned, but you are correct, that requires you to have separate audio cabling.
Sorry. |
#5 | Link | |
The SA8000HD does NOT have an HDMI output. That is incorrect above.
I would complain to COX. My local TW does the same thing. They keep giving me excuses of how they just spend all the money they had on buying out Adelphia. They say that they have no money to purchase new STB's.
__________________
#9 | Link |
Ah, you are right. My Cox system doesn't carry that model. Regardless, you are not going to get anywhere demanding a specific converter from Cox.
1) They're not going to do it. Maybe if they got some kind of huge influx of calls from customers demanding that specific model. Mayyyyybe. But I doubt it. 2) There is absolutely no financial gain to Cox by doing this. |
#11 | Link |
New Member
back in the USA
Just got back in the USA after 8 yrs and bought a SOny HDtv. I am in Georgia and have Cox cable. I ordered the HDMI cable with the TV and I am now wondering if I will be able to use it when I get the TV. Do the converters Cox leases have HDMI connections now?
If they don't is it better to just purchase a converter from another source? If I do would it work with Cox? New to HD so feel free to talk to me like a 1st grader...... |
#12 | Link | |
#14 | Link |
Component video. Red/blue/green RCA plugs.
__________________
My modest setup <-- Updated! |
#16 | Link |
A QAM tuner should scan and find whatever channels, HD or standard digital, are in the clear. They're supposed to at least provide the locals with a basic subscription, and probably a couple others. I'd be very surprised if they encrypted everything and required a cable box. They most likely won't advertise that they send stuff in the clear, but there should be some.
They'll be different channel numbers than what's on the cable box, and will probably have a decimal, something like 52.2. The way to find out is to hook up the TV directly to the cable and run the scan.
__________________
#17 | Link |
According to Cox, that's not the case. Here (Baton Rouge) they told me we can get 7 local HD channels without the cable box. But I'm just now checking out a HDTV I got my mother and it can't pick up a freakin' one of them! It says the signal is too low for all 7! So Cox FAIK could be "extorting" it's customers and forcing them to pay more for a freakin' cable box just to view the local channels in HD, by purposely limiting the signal of those local HD channels.
__________________
God Bless, -Clint Last edited by Clint S.; 01-01-09 at 08:45 AM.. |
#18 | Link | |
__________________
God Bless, -Clint |
#19 | Link | |
Since they are much higher frequency than traditional cable channels, the splitters and other devices that worked for standard cable may dramatically reduce the signal strength on the QAM stations. You need splitters, amps, and cables rated to 1000Mhz or greater all throughout the distribution system. The higher the frequency, the more the signal strength is reduced by those devices, or even cable length. Another hidden culprit could be an old VCR that the cable connects through. Their internal splitters won't pass QAM frequencies hardly at all.
__________________
I Will Be DRM Free WinXP Will Never Be Found Upon My HTPC Let Alone Vista or MCE Burma Shave |
#20 | Link | |||
NBC WVLA.......Ch. 3......093-1 (703) ABC WBRZ ..........Ch. 5.....100-1 (705) FOX WGMB...........Ch. 6.....099-2 (706) CBS WAFB........... Ch. 7.....100-4 (707) WBRL..................Ch. 10....098-2 (710) WLPB..................Ch. 12.....093-2 (712) KPBN..................Ch. 13......073-1 (713) The (700's) are the channel # using the cable box. Taking the first one as an example, that ch. # is 93.1, but on the remote you have to press 093-1 to get to it (I did it like that so my mother wouldn't get confused, the column in the middle like "Ch. 3" is the old # on basic SD cable). The channels "load", but the screen is blank, the signal meter is 0 and it says "low signal". Quote:
__________________
God Bless, -Clint |
#22 | Link | |
) That's just the local TV channels they (Cox) broadcast in HD that allegedly do not require the cable box. But I can't pick up any of them. I can't try on another TV because the other HDTV doesn't have the ATSC/QAM HD tuner, it's the type that must use a cable box to display HD.It wasn't easy getting the list, I had to ask and ask and ask, and I kept getting "I'll check into this and let you know" for weeks before someone finally sent it. What I asked was "which channels can an HDTV receive that do not require the cable box". 7 is pathetic, we should be able to receive ALL up to channel 99, all basic cable channels and we should NOT be required to have to key in the 700x series of numbers (therefore the cable box) to view HD content! But they extort their customers into shelling out even more $ per month just to be able to use their HDTV sets! So any HDTV with the ATSC/QAM tuner is totally useless and a waste of money with Cox if you want to watch HD content! That should be illegal. From what I've heard, they're only legally bound to show the local channels in HD with no box. But obviously they've found a way around that by "capping" or limiting the HD signal of said local channels so they can't even be picked up. So my mother is going to have to pay more $ per month to watch HD content. And the have the gall and audacity to claim "All HD content is free", that's BS. So I'm wondering if anyone has been able to view any HD channels on cable without using the cable box. EDIT: Sorry, I'm also posting in the Baton Rouge forum and I got this forum confused with that one. So everything I said above is for local Baton Rouge customers only, I don't know if that applies to other areas of the country.
__________________
God Bless, -Clint |
#23 | Link | |
Basic analog cable won't use QAM, it should use the analog tuner. If you can't get either of those, sounds like the signal needs to be boosted or maybe unfiltered.
__________________
#24 | Link | ||
__________________
God Bless, -Clint |
#25 | Link |
Any filters would have to be removed by the cable company, but I think that's actually unlikely to be your culprit, now that I think about it. It's probably a low signal and the cableco just needs to juice it up at your place. I don't know if an amp you install will work or not.
Either way, I don't think they're intentionally limiting your service, I think you just have a less than optimal signal. More them being sloppy or inattentive than anything outright fraudulent.
__________________
#26 | Link | |
__________________
#27 | Link | |
__________________
God Bless, -Clint |
#28 | Link | |
What does the "filter to block 23+" mean exactly?Thanks.
__________________
God Bless, -Clint |
#29 | Link | |
2-99 is usually called "expanded basic" and when cable was all analog, it was like the biggest selection, minus the premiums like HBO. TVs started having analog tuners built in to receive these. These are the so-called "cable ready" TVs, although since digital came along that term has fallen into disuse. But if you still have an analog tuner, you should get those channels as long as the cableco sends an analog signal and you subscribe to expanded basic. If you don't subscribe to expanded basic, the cable company can put a filter on to block channels 23 on up. Now if you just have the lowest basic, there should still be HD channels coming in through clear QAM, but sometimes the filters screw with it. If you're getting 2-99, there's probably no 23+ filter in place, and it's more likely to be a weak signal.
__________________
| Bookmarks |
| Thread Tools | |
