#1 | Link |
cable box problem.
One of my scientific atlantic cable boxes is not receiving all the channels. Many of the digital channels do not work with at all one one of the tvs in the house. When i tried it on a different tv from a different cable line it works perfectly. Could it be a weak signal causing this problem ? I have thois upstairs cable line split 3 ways. Might a booster fix this problem?
Thanks in advance |
#4 | Link |
OFFICAL HOME OF HDTV
An Amp isn't going to solve every problem! If you have the problem on just one line then the line or an end connection may be the problem. You need to test your signal stregth before you go throwing an amp at the problem.
__________________
"PLEASE HELP STOP HDTV ABUSE! FEED YOUR HDTV AN HD SIGNAL!" |
#5 | Link | |
Three way splitter, likely with - two -7db outputs and one -3.5db. I'll bet any money that he's tried the box on the line with the -3.5db loss and that's why it works fine.
If you call your cable company, they'll probably come out and diagnose the problem for you AND perhaps even provide the equipment to rectify it for free. |
#6 | Link | |
| Bookmarks |
| Thread Tools | |
