AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > Video Components > Cable, Digital Cable - Non-HDTV
Forum Jump
Old 01-20-07, 09:25 PM   #1   |  Link
vancouver
Nolan B
Cable Box advanced setup questions
I have a couple of questions about the below cable box my cable company cant even answer.
http://www.shaw.ca/en-ca/ProductsSer...ware-HDPVR.htm
1. In the advanced setup menu there is an option called "4:3 Overide" and the choices are 480i, 480p or stretch.
I already have "TV screen type set to 16:9 (because mine is)" and output set to 1080i.
2. For some reason since I go my new cable box I can only set the sound options on my Processor to Dolby settings i.e. Dobly Digital 2.0; DD PL11 (music or cinima); Dolby Digital. I can not set to settings like 5 Channel stereo. This is not something I had an issue with in my last cable box. Any ideas?
vancouver is offline   Reply With Quote
Old 01-21-07, 04:34 AM   #2   |  Link
lumpy9138
Is the audio set to matrix stereo in the menu?
lumpy9138 is offline   Reply With Quote
Old 01-21-07, 01:06 PM   #3   |  Link
nyanga
New Member
Answer to #1. - Set the screen size to 720p for best results. If you are satisfied with your T.V. at the 1080i settings then set it to that.
Answer to #2. - In the guide's setup menu set the audio to advanced w/matrix and the compression set to heavy. This optimizes the audio output that the program you are watching can deliver. Checking the info on a particular show will tell you what the sound output is ie. dolby digital, dolby 5.1 etc...
nyanga is offline   Reply With Quote
Old 01-21-07, 01:11 PM   #4   |  Link
nyanga
New Member
Sorry, I forgot to put this in the last post... The 4:3 override is if you want the cable box to either stretch all programming or not. I suggest leaving it to 'off' and letting your T.V do the stretching or not
Old 01-22-07, 10:26 PM   #5   |  Link
bradman
Assuming you have the STB connected to the receiver via optical or co-ax,the receiver is defaulting to the digital mode...there should be an option to select digital via manual instead of automatic.
Alternately,you could run a set of RCA's from the STB to another input on the receiver to utilise analog sound fields.
The 4:3 override functions as a sort of scaler if you select 480p;try both 480i and 480p to see which looks best on your display.
This will only affect the analog/SD channels.
It is my understanding that the "advanced" and compression /matrix audio settings only apply to the analog audio out on that box,as well.
When connected via digital,the options have no affect on the sound,imho.
bradman is offline   Reply With Quote
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.11014605 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
