AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > Video Components > Cable, Digital Cable - Non-HDTV
Forum Jump
Old 01-23-07, 02:20 PM   #1   |  Link
blackzc
Motorola service menu. How do i access it?
Its been so long since ive been in it i forgot. Does anyone know how i get into the service menu on the motorola DVR single tuner?
blackzc is offline   Reply With Quote
Old 01-23-07, 04:00 PM   #2   |  Link
Melanotheron
Power "off" on the box and then press "menu" button on the box. That should get you into the service menu screen to change resolutions and closed captioning options.
Melanotheron is offline   Reply With Quote
Old 01-23-07, 04:03 PM   #3   |  Link
blackzc
Thank you.
Old 01-23-07, 06:13 PM   #4   |  Link
kenglish
Isn't there also a menu for looking at carrier frequencies, SNRs, and such?
__________________
Ken English, Sr. Engineer, KSL-TV/-DT.
"Not a REAL Engineer, but I play one in TV"
kenglish is offline   Reply With Quote
Old 01-23-07, 06:37 PM   #5   |  Link
R300
Power + OK\Select <----twice
That should bring up the diagnostics menu.
R300 is offline   Reply With Quote
Old 01-28-07, 09:16 AM   #6   |  Link
Perch33
Is this the same for the dual tuner as well?
Perch33 is offline   Reply With Quote
Old 01-28-07, 09:37 AM   #7   |  Link
Melanotheron
Yes, it is the same procedure for the dual tuner....that's what I have, so I know it works.
Old 01-29-07, 07:36 PM   #8   |  Link
bmackrell
USS Mackerel
bmackrell's Avatar
AVS CLUB MEMBER
Classified Rating: 100% (3)
any thoughts on how the settings are saved. I have a comcast motorola HD box in my HT and I can never get it to save the resolution settings. the signal is going through a processor to a projector. Every time I fire up the theater to watch HDTV, I have to invoke the service menu and set the aspect ratio and resolution. I have tried starting things up in different sequences.
billmac
bmackrell is offline   Reply With Quote
Old 01-29-07, 07:49 PM   #9   |  Link
Melanotheron
Sorry but I have never run into that problem. Once set, mine stays that way. I do keep my box on all of the time, don't know if that makes a difference.
Mel
Old 01-29-07, 08:07 PM   #10   |  Link
Melanotheron
I just checked the user manual for both the single and dual tuner Motorola DVR and it says "To exit the menu and save your settings, press the POWER or MENU key." Hope this helps.
Mel
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.14922905 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
