#1 | Link |
1080p24 7.1 LPCM
MHD vs SACD/DVD-A
I have not own a SACD or a DVD-A but whenever I listen to MHD's music for quite
some time now and I really like the ambience. My question is, is it the same quality if you listen on MHD (5.1) and if you listen on SACD/DVD-A(5.1)?
__________________
There is always someone out there that gives you opinion of a product that they don't even own. |
#2 | Link |
No. As far as I can ascertain, MHD is using Dolby Digital, not sure at which bitrate, so you're getting similar quality to DVD-Video.
SACD and DVD-Audio are a notch higher - not psychoacoustically compressed, and usually a higher bit-depth and sample rate. |
#3 | Link | |
1080p24 7.1 LPCM
a little confused.
__________________
#4 | Link |
5.1 Music Addict
After a DVD-Audio's Meridian Lossless Packing data is uncompressed, you get back multi-channel PCM in high res.
SA-CD's are lossless packed as well using, I believe, Direct Stream Transfer (DST). The de-compression stage takes you back to a Direct Stream Digital (DSD) track. Consumer DSD is 1 bit word length with much, much higher sampling than DVD-Audio (in the MHz range rather than the kHz range). Pro grade DSD recordings are done at 8 bit word lengths in order to apply DSP manipulation and not lose data or add noise during processing (much like pro grade PCM mastering work is usually digitally manipulated at 32 bits).
__________________
Studios, just say "NO" to DNR and EE!!! Say "YES" to full quality 1920x1080p high definition video and 8 channel, 24/96 (or greater) multichannel audio (full lossless or uncompressed PCM)!!! |
#5 | Link | |
Surround Music Fan
That can be either DSD wide (8-bit / 64fs) on Sony's mixing solution or PCM (32-bit / 8fs) on the Philips solution. Cheers,
__________________
Contributing Editor & Surround Music Reviewer Widescreen Review Opinions are mine, not the publication I write for. |
#6 | Link | |
If 5.1 is coming out of MHD its most likely the AVR using PLII or Neo6 or any other matrix-surround effects avaliable on the AVR you are using. |
| Bookmarks |
| Thread Tools | |
